Equipment shed.
/ Equipment shed. #1
travlitt
Texas
8050C Branson, Branson 2400, 8N Ford, Round Fender John Deere 110, 3 60" ZTR mowers, a bunch of ride on mowers, 8' Brush hog , 15' Bat wing
Getting ready to add 1200 sq. ft. to my equipment shed.
Day 1
Removing trim.
/ Equipment shed. #2
Good Deal...
An equipment shed has got to be one of the best cost wise for keeping equipment in order... looks good.
/ Equipment shed. #3
Looking forward to more pics. Are you using 2x4 metal tubing? I have some of that and it's super heavy. Good thing you have those forks!!!
/ Equipment shed.
Hello Eddy, Yes I am using 2x4 metal tubing. The rafters are 30' long. 2' spacing. I will post pictures as I progress along. It is a slow go working along. Some times I need to be at both ends at the same time.
You and the wife have a great evening.
/ Equipment shed.
More framing.
/ Equipment shed. #6
I like how you hold your framing in the air. When one tractor isn't enough, use 2!!!!!
/ Equipment shed. #7
That's quite a project!! Looks good!!
Did you use 2x4 metal tubing for strength over the span? And what brand/model of forks do you have for the front of your tractor. I need to pick up something like that.
/ Equipment shed.
/ Equipment shed.
Eddie the big tractor is holding the rafters up off of the temp header (wood post with temp header). I am using the little tractor to put in place the permanent steel header. That header is mid-span of the 30' addition I am adding on. The header is made with 1.. 4"x4" x 1/4" sq tubing and 2.. 2"x 4" tubing. Support post are 4"x4" x1/4" tubing set in the ground 3' in a 12" hole with rebar. Each post has 3 or 4 80# bags of sakrete.
Some details of the header I installed.
/ Equipment shed. #11
Nice work. Anxious to see the progress.
I added 600 sq ft to my machine shed last Summer by myself. It's good for the Soul. Bad for the back. :D
/ Equipment shed.
I sure agree on the good for the soul and bad for the back.
My wife is my helper, does a good job.
I will have a total of 2000 SQ. ft when finished.
I will have 2 overhead doors and one walkthrough.
/ Equipment shed.
Additional framing and some construction details.
How the new rafters are attached to the existing shed.
First attached with screws.
Then welded with E 6011 1/8 rod. Be advised, I am not a welder.
/ Equipment shed. #14
Oh wow, you need to take some pics of the whole building. I'm a bit confused about what you did to start the add-on? Remove siding? So you are more than doubling the size of your building? Awesome!!!! :)
/ Equipment shed.
I started out with a 40' shipping container. I built a shed and it was attached to the container. That shed was 20'x40' To start this addition to the existing 20'x40' shed, I had to remove the TRIM on the existing shed, 2 nd picture.
Origional shed. I removed the blue trim.
When I get all finished it will have a total of 2000 Sq. ft and be fully enclosed with 2 overhead doors and 1 walkthrough.
/ Equipment shed. #16
Yep, got it now!! Thanks for the explanation. :)
/ Equipment shed. #17
Did you have it engineered? I'm wondering why the metal spans so close together for just a roof?
/ Equipment shed.
Not engineered. Just me, I always overbuild. Mainly its because the way I had to run the rafters.
/ Equipment shed. #19
How did you attach the rafters to the side of the container? Did you drill through it to attach bolts?
/ Equipment shed.
Like this.
New, Landhonor Skid Steer Pallet Forks  (A62679)
New, Landhonor...
213078 (A64276)
213078 (A64276)
Multipurpose Skid Steer Mount Backing Plate  (A62679)
Multipurpose Skid...
2019 John Deere 4044M (A62177)
2019 John Deere...
2020 Club Car Carryall 700 Gas Utility Cart (A61567)
2020 Club Car...
2009 Featherlite Race Car Hauler Enclosed Trailer (A62613)
2009 Featherlite...
