Entry Gate advice appreciated.
   / Entry Gate advice appreciated. #1
EddieWalker
Epic Contributor
Tyler, Texas
Several, all used and abused.
I'm in the planning stages of building an entry gate for my place and keep going back and forth between a sliding gate or a swing gate. I have power to the gate already, so that's not a concern. The gate will be on the heavy side, but I haven't made it yet. As of right now, I'm thinking 8 feet tall and 14 feet wide. I'm also looking at different motors to open and close it, but that's not such a big deal since there are so many out there. It will probably be a commercial unit.
Sliding or swing? What is the most hassle free? What are the pros and cons?
Thank you
   / Entry Gate advice appreciated. #2
Thank you
With a slide gate you will have a smaller path to keep clear for the gate to operate.
   / Entry Gate advice appreciated. #3
Whatever you decide to build, I'd make sure it's very stiff so the gate doesn't settle. Lots of cross bracing. I have seen alot of nice gates left open because they are difficult to move.
   / Entry Gate advice appreciated. #4
I've got a sliding gate with a solar opener. Have to replace the battery (deep cycle) every 2 - 3 years. One thing to be aware of is that when an ice storm happens, you'll need to clean off the ice to use the gate.
   / Entry Gate advice appreciated. #5
Given that Eddie is in TX, that shouldn't be a very frequent problem...
I would say sliding.
Aaron Z
   / Entry Gate advice appreciated. #6
I see more gate problems from leaning posts than from sagging gates.
Bruce
   / Entry Gate advice appreciated. #7
I like swinging, personally....sliding just looks too industrial for me.
As for sagging, put an 6inch I-beam in a couple yards of concrete, then put few tons of rock around it and you won't have a post moving problem. :D
Mine: 2 ten foot gates.
ry%3D400
   / Entry Gate advice appreciated. #8
I prefer swing gates and the wider the better.
This pic was the gate at my last home. 2 12' gates for 24' opening. The posts are old utility poles set 5' in the ground.
I made the hinge mounts adjustable to keep it even but never had to adjust because the poles were so ridged.
Spend your money on the opener, I had HF that worked great until it lost the codes and I couldn't get them back.
Then went to a Might Mule and it kept messing up so I ended up just opening the gate manually.
Nothing like two trips in and out of your vehicle to come or go!
   / Entry Gate advice appreciated. #9
Eddie: I have been using a swing gate for eight years, old RR ties hold it up. Only caution I can tell you is in that time it has been hit twice by guys pulling trailers, requiring adjustments.
   / Entry Gate advice appreciated. #10
Aesthetically it is swing gates every time. Like TnAndy says, slide gates look functional but have no personality.
UNUSED CFG INDUSTRIAL PD680-PZ POST POUNDER (A51244)
UNUSED CFG...
2002 JOHN DEERE 450H CRAWLER DOZER (A51406)
2002 JOHN DEERE...
2013 Ford E-250 Cargo Van (A50323)
2013 Ford E-250...
2017 Ford Fusion Sedan (A50324)
2017 Ford Fusion...
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
2013 Derek Digger (A50323)
2013 Derek Digger...
