Enough Trailer for my Tractor??
/ Enough Trailer for my Tractor?? #1
34Willys
Glide,OR
'18 Kioti CK2610HST
I have an opportunity to purchase a nearly new/one trip trailer from a friend. A 16', dual axle flatbed with stored ramps, #7000GVW. The tag states not to load more than #5400 lbs.
I have a 2018 Kioti CK2610 tractor, loader, backhoe, with loaded rear tires.
My quick calculations show I would be under max weight, but not by much.
Is this trailer worth buying, or should I look at something larger. I would only rarely be towing the tractor and mostly local runs less than 75 miles.
Thanks for your input.
Patrick
/ Enough Trailer for my Tractor?? #2
Only you can determine if it makes economical/practical sense to get a given trailer for its price (figure in how often you need to move it, if there are rentals available nearby, etc). You don't mention your truck but also consider if your truck can manage 700-1000# of tongue weight and 7k of towing capacity.
As far as enough trailer - does 5400# fit all of the parts you want to put on it? Is 16' long enough for those parts especially arranged to give the trailer about 10-15% weight on the tongue?
Given that your friend has it, can you borrow it to see if you can put your tractor in a good position on it with the implements you expect to be carrying during the tow?
/ Enough Trailer for my Tractor?? #3
I calculated ~4923lbs w/ the 2610 loader, 2475L backhoe, and 50gal total water/windshield fluid/glycol fluid for the tires (assume R4/R14?). Or ~4975lbs w/ the 4030 loader. Easy enough to just round it up to 5000lbs and compare that to the 5300lbs capacity on the tag (not 5400lbs) and you can see that you really are squeaking right in there. Not that is a bad thing necessarily, as that would probably be the most that that tractor would weigh given that if you were just mowing, you would drop that backhoe for a lighter bushhog, and probably the front bucket too, if not the whole loader. The main problem is does it have enough room on it for the longest configuration (probably brushhog) and can you move it enough to have the load distributed correctly, as @ning noted above.
edit: kybd can't spell correctly late at night...
/ Enough Trailer for my Tractor?? #4
It wouldn’t be my first pick in trailers but it’s probably enough to work if you don’t plan on hauling a bunch of other stuff in addition to the tractor.
/ Enough Trailer for my Tractor?? #5
I guess there are questions you must answer. I see the load limit is stated at 5300 - I guess the trailer weights 1700 #. First, does it have brakes on 2 or 4 wheels. I don't know about your state, but here, over 3500 can be one axle, over 5000, has to be both axles to be legal. Second, just how close is the weight you want to haul. Does full tractor fuel, chains and binders put you over weight? It is a nice looking trailer. I like the stake pockets for tie downs and it does have corner D rings. And the bed looks clean. But if you use it overweight, it may not trail as well or stop as well as it was intended. My trailer is 14k, but it is a tilt bed which makes it heavy - 3700# - When I load it to 10K with my tractor and implements, it feels heavy and I am glad it is not overloaded. Also, consider the upgrades you may want to do to the trailer - as in adding a tool box.
Also, consider Ning's comment about the space to move weight (load) forward or back to adjust tongue weight. You may quickly wish it was 18 or 20'.
Nice looking trailer, just make sure it fits your needs. One last comment - I might want to know where it was made and does the company use certified welders. Best wishes, Larry
/ Enough Trailer for my Tractor?? #6
A 16 foot 7K trailer is not much more than a utility trailer, consider the advice given above and do the safe thing. Now if it is a great deal and you have a use for it then go ahead but be aware of it's limited capacity. I have a 16 foot 7K trailer and use it a lot but not for my tractor and equipment.
/ Enough Trailer for my Tractor?? #7
My take is that if you are under the manufacturer rated weight, you are good. Typically such ratings include a safety factor, meaning the trailer could actually handle more weight but then you have less margin for error in load positioning, weight estimating, road conditions, etc.
/ Enough Trailer for my Tractor?? #8
To me it would depend on the price. Killer deal? grab it and try it out, can always resell and get your money back. Close to full price? pass, and get the proper setup.
I have the exact same frame tractor, and am very glad that my package deal came with a 20', 10k car-hauler trailer. Gives plenty of room to position the TLB for weight distribution, and carrying other attachments as needed.
/ Enough Trailer for my Tractor?? #9
I’d start looking for a 10k trailer to be on the safe side.
/ Enough Trailer for my Tractor?? #10
Then you go 10k 14k, then your truck has to be 2500 or 3500.......and the list goes on and on and on. Just buy what you think you need and be happy. I bought a 20' 10k tilt trailer and haul my 4600# compact tractor with my 2004 Chevy 1500 with adequate setup and it does all that I need.
/ Enough Trailer for my Tractor?? #11
? You just contradicted yourself and said your own 10k, 20' pulls fine behind your 1500, with a similar size tractor. Don't necessarily need a 2500 if you have a 10k tow rating or better on your 1500.
/ Enough Trailer for my Tractor?? #12
Price would be the determining factor at this point all else having been considered
/ Enough Trailer for my Tractor?? #13
Well, PLENTY of TBN people told me I CAN'T pull a 10k trailer SAFELY with my 1500, but I do. The point is, just like you know come and point out how I contradict myself.......there is always one in the crowd that will point out that you're doing it wrong or unsafe. That you will need a 2500 or 3500 to be safe yadi yadi etc etc. I'm still a few hundred # below my 1500's max tow rate of 7800#. But then again, I wasn't asking for advice, simply state....do your own research with your own parameters and get what you can afford and work with it.
/ Enough Trailer for my Tractor?? #14
I'd be more concerned about the tow vehicle. Don'
t expect to pull much of anything with a weenie truck (like a Ford F150) it may pull it fine but get in as panic situation and you may not only run out of braking power but rear ending someone else because you cannot stop is 'assured clear distance' in any state and will garner you a ticket plus you'll be 100% liable for damage to the other vehicle and possibly a personal injury claim.
/ Enough Trailer for my Tractor?? #15
Gotcha. Are you quite sure your trailer is under 3200 lbs? My 10k, 20' car hauler is 2900 lbs, without any tilt!
But just for the record... not necessarily great advice to recommended other folks tow at 95% to %110% of their legal towing capacity. Might toodle around town just fine, but a panic stop could be another story.
/ Enough Trailer for my Tractor?? #16
Trailer in pic pretty much matches my 16' in all aspects. I've hauled all three of my CUTs up to 50 mi each way w/o incident either to buy or to MIE to have bits installed. Having o'loaded it once for a short trip I suggest that tire capacity/condition will typically be the weak point.
/ Enough Trailer for my Tractor?? #17
Patrick
View attachment 714113View attachment 714114
You didn't give us a price but asked if it was worth buying. I think it is because a good deal is a good deal. I have one like it and will haul 15k if I need to. Key is good trailer transport type tires if 15" or some LT tires if 16" , flats are a nightmare on the road. Once I had two flats. Carry two spares now. I carry extra shackles too, but I am moving up to slipper springs soon, and changing these drop axles. I've never had brakes. It has new hydraulic brakes but never hooked up. I have snapped off two hammerblow hitches hauling too much. So I never thought one of those brake actuator hitches would hold up. But I have electric brakes on the straight axles. I do want to be legal. Keep a hi lift jack and some lube with you. Flats on the hi way are dangerous. Plywood squares and blocks are handy items when you end up in flat city.
/ Enough Trailer for my Tractor?? #18
Ive been hauling equipment daily for almost 20 years on trailers that are loaded to very near to their rated max capacity without incident. the rated capacity is a safe rating with a significant margin before it becomes unsafe. if the price is right, go for it.
/ Enough Trailer for my Tractor?? #19
Heavy duty trailers have more safety margins but in my experience trailers trailers below 10,000 pounds don’t like being overloaded especially for prolonged use.
/ Enough Trailer for my Tractor?? #20
kinda like an expiration date , a serving size, or a speed limit for that matter.
recommendations, aside from the speed limit of course.
