Enlarge category 1 sized holes to accommodate category 2 pins.
   / Enlarge category 1 sized holes to accommodate category 2 pins. #1
stumblinhorse
Platinum Member
Grand County, Colorado
Case Farmall 75C, Kubota L3130
Have a new to me large heavy 3 pt implement. My Case is cat 2. The top link holes fit the cat 2 pin but the lowers don’t. Definitely cat 1 sized. There are 2 sets of holes for pins. I hate the sleeves since they often times slide side to side and are a nuisance it get on when attaching. I am thinking about enlarging the holes to fit the cat 2 pin diameter. There is plenty of material to take 1/8“ or so that is needed. Width isn’t an issue so any advice?
   / Enlarge category 1 sized holes to accommodate category 2 pins. #2
wouldn't be easier to just tack weld the sleeves in place on the implement
i have seen replacement balls that fit into the lower arms with different size holes the ones I have seen were to go down a size but probably available going the other way as well
   / Enlarge category 1 sized holes to accommodate category 2 pins. #3
I have a quick hitch that uses cat 3 size pins.
On my implements I have replaced some of the pins with cat 2 and tacked welded the sleeve on. The other pins are cat 3. They dont bend like the cat 1 does.
Enlarge the holes snd put the bigger pins in.
   / Enlarge category 1 sized holes to accommodate category 2 pins. #4
It's always been easier for me to switch a few pins. Easy for me to say now that my remaining stuff all Cat-1 (3 CUTs) so it depends on which implements are used on which tractor(s). That or I'm just tired and I apologize ... o_O
   / Enlarge category 1 sized holes to accommodate category 2 pins. #5
I converted an implement from cat 1 pins to cat 2 pins for less than $20 and very little effort by buying this product from tractor supply company:
it is the type of attachment where the arm is between the 2 holes per pin. You have to put the sleeves in the arms lower the arms and then put in the pins.
Photos probably would help
Definitely leaning this way. All my cat 2 implements work the same with 2 sided connections with a pin that slides thru. I guess that is because they are all over 1500 pounds each.
   / Enlarge category 1 sized holes to accommodate category 2 pins. #10
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A52748)
Adams Load Out...
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
1986 ASPT 30ft S/A Pole Trailer (A51692)
1986 ASPT 30ft S/A...
1997 East Manufacturing Walking-Floor Trailer, VIN # 1E1U1X287VRE22897 (A51572)
1997 East...
John Deere 1110 Field Cultivator - Heavy-Duty Soil Finisher for Precision Tillage (A52748)
John Deere 1110...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
