Enlarge category 1 sized holes to accommodate category 2 pins.
   / Enlarge category 1 sized holes to accommodate category 2 pins. #1
stumblinhorse
Grand County, Colorado
Case Farmall 75C, Kubota L3130
Have a new to me large heavy 3 pt implement. My Case is cat 2. The top link holes fit the cat 2 pin but the lowers don’t. Definitely cat 1 sized. There are 2 sets of holes for pins. I hate the sleeves since they often times slide side to side and are a nuisance it get on when attaching. I am thinking about enlarging the holes to fit the cat 2 pin diameter. There is plenty of material to take 1/8“ or so that is needed. Width isn’t an issue so any advice?
   / Enlarge category 1 sized holes to accommodate category 2 pins. #2
wouldn't be easier to just tack weld the sleeves in place on the implement
i have seen replacement balls that fit into the lower arms with different size holes the ones I have seen were to go down a size but probably available going the other way as well
   / Enlarge category 1 sized holes to accommodate category 2 pins. #3
I have a quick hitch that uses cat 3 size pins.
On my implements I have replaced some of the pins with cat 2 and tacked welded the sleeve on. The other pins are cat 3. They dont bend like the cat 1 does.
Enlarge the holes snd put the bigger pins in.
   / Enlarge category 1 sized holes to accommodate category 2 pins. #4
It's always been easier for me to switch a few pins. Easy for me to say now that my remaining stuff all Cat-1 (3 CUTs) so it depends on which implements are used on which tractor(s). That or I'm just tired and I apologize ... o_O
   / Enlarge category 1 sized holes to accommodate category 2 pins. #5
I converted an implement from cat 1 pins to cat 2 pins for less than $20 and very little effort by buying this product from tractor supply company:
it is the type of attachment where the arm is between the 2 holes per pin. You have to put the sleeves in the arms lower the arms and then put in the pins.
Photos probably would help
Definitely leaning this way. All my cat 2 implements work the same with 2 sided connections with a pin that slides thru. I guess that is because they are all over 1500 pounds each.
   / Enlarge category 1 sized holes to accommodate category 2 pins. #10
2019 DODGE RAM LARAMIE 5500 FLATBED (A58214)
2019 DODGE RAM...
500BBL WHEELED...
2018 DODGE RAM 2500 (A58214)
2018 DODGE RAM...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A58017)
2018 INTERNATIONAL...
DEUTZ MARATHON...
2007 Homemade Pipe Trailer (A55973)
2007 Homemade Pipe...
