Engineered lumber span chart
/ Engineered lumber span chart #11
I think the formula your looking for here is the Pythagorean Theorem which states: the square of the length of the hypotenuse of a right triangle equals the sum of the squares of the lengths of the other two sides. As has been simply stated A squared + B squared = C squared
Why not go with a scissor truss (for a vaulted look) or an attic truss (if storage is what your after)?
/ Engineered lumber span chart #12
Chris,
Probably true, but how many really get to drive the train??/w3tcompact/icons/wink.gif
Al
Thanks for the link...trusses would do the span, but I am interested in putting the space to use so they are out. A good (and probably cheaper) solution if I didn't need to use the space...thanks.
/ Engineered lumber span chart #15
You can get a room truss that has the walls built in. They are not cheap, but go up quickly so labor is usually less. This only counts if you are hiring it out. They are also stronger. and usually take up no more room than a framed in knee wall would. Think of it like a triangle with a rectancle inside of it. The bottom cord is used as your floor joist and the top as rafters. I highly recommend them, and the joist company engineers the loads and gives a warrantee with them as long as they are installed correctly
Check the prices with different companies, sometimes the prices vary greatly. Some times you can get lucky and they are the cheapest alternative to use.
/ Engineered lumber span chart #16
What your describing is an attic truss. They usually come with a 2 x 8 or 2 x 10 bottom cord. I've installed them on garages for people. They tell the local inspector the area is for storage. As soon as they get the final, walls go up and carpeting goes down. Go figure, who'd want to use a carpeted area for storage.
/ Engineered lumber span chart #17
Around here they refer to them as room trusses and they are intended to be habitable rooms. The bottom cord will vary in size up to around a 2x12 depending on how the live loads engineer. They are used about 50% of the time and usually spaced on 16 or 24 inch centers. Once they go up the room is framed in as well as the rafters put in place. Attic trusses many times do not have the necessary head room or live load strength to be considered habitable.
/ Engineered lumber span chart #18
Must be a regional definition. The no headroom ones we refer to as storage trusses. We're talking the same animal, but with a different name.
/ Engineered lumber span chart #19
yep, ours have 8 foot headroom and up. some have tray ceilings built in. No wonder your inspectors look hard at the ones you see.
2019 PJ TRAILER 32FT GOOSENECK (A58214)
2019 PJ TRAILER...
CHALLENGER VACUUM PUMP (A60736)
CHALLENGER VACUUM...
Kuhn FC400RG (A60462)
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2018 Ford F-150...
2014 FREIGHTLINER CASCADIA (A60736)
2014 FREIGHTLINER...
