Engine Whistle at high rpms
   / Engine Whistle at high rpms #1
Pslone
TYM T 474
Im getting an almost whistling at about 2600 rpm on my t 474...anyone have any ideas on the cause? Any info would be greatly appreciated. Thanks
It does not have turbo, so we can rule that out. I will check the air filter and clean if necessary. Thanks for the suggestions, that would be a easy fix if that is all that it is.
I checked and cleaned the air filter. It did not solve the problem. It doesn't start to whistle until the rpm's are at about 2500 tp 2600 hundred. I've also checked the belts and they are within specs. This just started to happen after I was doing loader work where I was moving dirt, so the air filter made sense, but it was not that dirty. The tractor only has 100 hours on it. Thanks again if you can offer any more suggestions.
   / Engine Whistle at high rpms #6
Sounds to me like you have an intake hose leak. Check to make sure all the clamps are tight.
Thanks for the suggestions, I was able to tighten all the hose clamps, it did not work at first, but as I continued to work the tractor the whistling slowly went away. So I will update later to see if the whistling stays away. Thanks for all those who made suggestions, it's greatly appreciated. I'm new to the tractor world and to this forum, but am very thankful for all those who posses tractor knowledge...thats a great tool, especially to newbies like me.
   / Engine Whistle at high rpms #8
I've never run that many rpm on any diesel.
Thanks for sharing. I don't either, but due to my tractor being auto throttle, when I'm driving from one destination to another in all three gears, the tractor will at times reach those numbers, and until yesterday it's never made that whistling noise. I was inquiring as to what could be causing it...it did go away, but when the tractor cooled, it came back...its still a head scratcher to me. Thanks again.
2013 Dodge Charger Passenger Car, VIN # 2C3CDXATXDH646719 (A51572)
2013 Dodge Charger...
2024 Greatbear Forklift Jib (A51573)
2024 Greatbear...
2006 FORD F-150XL TRITON EXT CAB TRUCK (A51243)
2006 FORD F-150XL...
1067 (A53342)
1067 (A53342)
Single Axle Rear Truck Frame (A51692)
Single Axle Rear...
JOHN DEERE 648R LOT NUMBER 108 (A53084)
JOHN DEERE 648R...
