Engine Speed???
/ Engine Speed??? #1
UpstateNYMarine
Clinton, NY
2007 John Deere 2320
Just curious for those of you with MMM's and Rotary Cutters. What Engine Speed do you use while running either of them? I have a 2320 and was just curious. I have read the manual for both but curious what others have found to be the best. Thanks in advance for the replies. :D
/ Engine Speed??? #2
For a rear PTO cutter, it depends on what you're cutting. If it's anything tall, or with a thick stem, you'll want to run at, or close to, "rated" RPM. Our field is a former corn/bean field, presently "growing" mostly ag weeds, in the early stage of a prairie reconstruction. I run at "rated" (2700 engine = 540 PTO on a JD790 [5:1 ratio, easy math]) most of the time, just so I can run the machine itself fairly fast on the field. When I want to slow down, rather than selecting a lower gear, I can just back down the hand throttle to about 2200 RPM (= 440 RPM PTO), and the cutter (cheapo 5' KK) doesn't skip a beat. 'Course, I have nothing more than about 3/8" diameter to cut (if that), although it's sometimes several feet tall. If you have thicker/taller/tanglier (is that a word?) weeds to cut, you'll probably want to stay closer to 540.
No experience with an MMM (we don't even have a mid-PTO).
/ Engine Speed??? #3
You should run the tractor at the rated RPM for 540 PTO speed. That is what the implements are designed for.
2001 THOMAS-INTERNATIONAL 3800 SCHOOL BUS (A62130)
2001...
2022 EZ-GO ELITE...
CRAFTSMAN 34IN RADIAL DRILL PRESS (A64281)
CRAFTSMAN 34IN...
159116 (A60430)
159116 (A60430)
2019 Toro Groundsmaster 7200 72in. Zero Turn Commercial Mower (A61572)
2019 Toro...
2007 MACK GRANITE CTP713B DUMP TRUCK (A64280)
2007 MACK GRANITE...
