Engine Shutdown
/ Engine Shutdown #1
JJPWAus
West Australia
Iseki TS1910, JD110
I am currently shutting down my tractor by closing off the fuel rack, I belive that my tractor is supposed to have a spring return butterfly on the intake manifold.
Am I causing any damage by shutting off the fuel rather than the air??
/ Engine Shutdown #2
John, I don't know anything about Iseki, but I think the normal way to shut down diesel engines is to cut off the fuel supply; some manually and some via electric solenoid. So I'm reasonably sure you're doing the right thing.
/ Engine Shutdown #3
<font color="blue"> Am I causing any damage by shutting off the fuel rather than the air?? </font>
John, No you won't do any harm, all diesels are shut down by cutting the fuel not the air to my knowledge.
/ Engine Shutdown #4
John,
I don't know how your tractor operates.I Believe you are not doing any harm by just shutting down the fuel.The only time I've seen an air shut off was when I worked on New York City Buses.
These buses used, at the time, the 671/871 GM Diesel engines.The blower/super charger had what they called a dump door sitting on top of the blower to cut off the air supply.This was only to be used in case of an emergencey.
/ Engine Shutdown
Bird/Vin/Bob
Thanks for the feedback, it's good to be reassured that it's not doing any harm.
/ Engine Shutdown #6
Hey Bird, Vinnie.
Maybe they all should have a air shut off placed forward of the air intake this way mice and small critters would be shut out.
/ Engine Shutdown #7
</font><font color="blue" class="small">( called a dump door sitting on top of the blower to cut off the air supply.This was only to be used in case of an emergencey. )</font>
Our diesel mechanic at work wes telling me about stuff like that. he said when he rebuilt an injector pump, he would have a 'choke' plate ready to close the intake in case of runaway...
Soundguy
/ Engine Shutdown #8
Many places where a volatile cumbustible gas may be present require the diesel engines to have a positive air shutoff. This is usually some form of clipgate valve or sliding gate that seals the air intake.
It's purpose is to stop engine runaway and prevent the combustible gas from going Bang.
Shuting off the air supply for a normal stop may entail a little fuel accumulating in the cylinders which in turn will leak down into the crankcase strippping lubricating oil from the cylinders as it goes. Would make for poor starting.
Egon
/ Engine Shutdown #9
I think I've heard a news story about ( though never witnessed ) a propane runaway at a construction site when they broke a gas main once time.
Soundguy
/ Engine Shutdown #10
Speaking of diesel runaway ....
My uncle (a truck driver) has on a couple of occasions experienced some slight, uncommanded acceleration while driving beside or through refineries. Apparently low hanging clouds of propane or natural gas getting sucked in the air intake. Nothing came of it, but he says it makes you feel a bit uneasy to say the least. I'd feel uneasy about the fact there is that much gas leaking, never mind the diesel problems! /forums/images/graemlins/shocked.gif
A more drastic, and terminal (to the engine), case was another relative with a GMC turbo diesel pickup. He had the turbo replaced but it must have been a poorly done rebuild and the bearings or seals or something went out. One day he started the truck, preparing to go out for the day, and it started to accelerate on its own. It was eating it's own engine oil by way of the bad turbo bearings. The faster it went, the more boost the turbo made and the worst the oil leak got. Cutting off the air supply involved tools and time and he wasn't too keen on climbing under the hood to do that, so all he could do was watch. He knew what was happening and what was to come, so he just pulled out a lawn chair and watched as the thing screamed and filled the neighborhood with smoke. Eventually it either used up all the engine oil or something just couldn't take it anymore - BANG!! and there were more pieces inside the engine than there used to be.
Lucky for him the guys that had replaced the turbo took responsibility and replaced the engine for him - about $8000 worth directly from GM.
/ Engine Shutdown #11
I've heard of old detroits syphoning their own oil, and sucking seals in when a choke plate was thrown over a runaway engine.
Kinda neat how determined the engine is to run..... guess a compression release lever would cure that...
Soundguy
/ Engine Shutdown #12
My Iseki 1610 which should be almost identical to your larger tractor is shut down via the spring butterfly on the intake.
I have to remember to open this when i wish to start the tractor.
/ Engine Shutdown #13
Here at work the guys were building a piece of road construction machinery that had a Detroit diesel in it.
Anyway the painter comes over with some paint and paint thinner to do some touch up work and accidentally turns over the gallon can of thinner next to the air intake while the engine was running.
Then engine just took off and they didn't call em screamin Jimmys for nothing. The lead line forman ripped the intake tubing off and start stuffing it full of rags trying to choke it off to no avail. The engine sucked the rags in and spit them out exhaust.
Finally someone grabbed a pair of pliers and clamped and fuel line shut.
TBAR
/ Engine Shutdown #14
Unless butterfly has a solenoid or cable actuator, it's probably just to keep critters and weather out. A spring return butterfly is normally opened by vaccum and closes by itself at shutdown. Most larger engines I've worked with have air intake shutoff as emergency feature for overspeed and is govenor actuated electrically or hydromechanically (oil).
/ Engine Shutdown #15
</font><font color="blue" class="small">( Anyway the painter comes over with some paint and paint thinner to do some touch up work and accidentally turns over the gallon can of thinner next to the air intake while the engine was running.
)</font>
if the engine overrevved from the paint thinner then crimping the fuel line did nothing at all, the diesel was running on the fumes of the paint thinner, so the only way to have stopped that woulda been to cut off the air as your boss tried to do, it was just coincedence that when they crimped the fuel line off was when the engine finaly used up the paint thinner that was in the intake.
/ Engine Shutdown #16
Hi John,
I have the service and repair manual for the Bolens equivalent model of your tractor. Shutting the fuel off is probably one god way to shut off the motor. However, the following is from the manual:
" The engine stopping device of this engine is an intake shuitter which is most popular among diesel engines. A butterfly valve is equipped on the intake manifold to close the air intake port to cut off the air to combust fuel. Consequently, the engine stops regardless of the fuel injection volume or engine speed. However, it is not recommended to close off the valve when the engine is running at high speed or is loaded, except in an emergency." HTH
Bill in CO
213085 (A64276)
213085 (A64276)
2012 KOALA BUMPER PULL (A67714)
2012 KOALA BUMPER...
1998 CHEVROLET C7500 (INOPERABLE) (A67714)
1998 CHEVROLET...
2017 Dodge Grand Caravan Van (A66738)
2017 Dodge Grand...
1995 Khronert 307 SS Single Comp 6,500 Gallon Insulated T/A Chemical Tanker Trailer (A68183)
1995 Khronert 307...
2016 CHEVROLET IMPALA LIMITED CAR (A66091)
2016 CHEVROLET...
