Engine Overhaul Kama 554
/ Engine Overhaul Kama 554 #82
Very nice Rob. I am glad you got it running. Nothing like doing it yourself. Chip really came through for you also. Nice to have such a good dealer network here.
Chris
Thanks all, you have been super supportive!
Jim, Chris and PAGUY,
It was certainly worth the effort when it fired up and ran as well as it did.
The fel will be not sweat to put back on. I don't know if you picked up on it or not, but I removed that blow by tube I had made going to the air intake. I put a regular breather on the Kama. That was the first thing I checked at all running rpm. Man, there is hardly any blow by at all ... I mean hardly anything. So the ring and valve job came out super good.
I am very pleased with that.
IH3444,
I didn't check the weight of each piston and connecting rod either.
But nevertheless, it ran a lot smoother and quieter than I remember from before. My manual told me about it but I neglected to do it. Next time I will.
Brad,
I found the problem with my air filter.
I found that the air filter did not shut off against the rubber seal. Apparently there needs to be another nut on the stem to push the filter completely against the cannister. I saw Loretta's Jinma had this extra nut which does that. It must have been that way from delivery and I never knew the difference until I was putting it back together again. So I added a washer and nut to keep the filter sealed against the back of the cannister. Now the air MUST go through the filter. I'll bet that's what caused the premature ring damage in the first place?
One thing I did see after running it the 15 minutes.
Towards the end of the high rpm run, I saw the oil pressure go down to about 30/35psi. I figure that one connecting rod journal where the bearing was squished was not perfect. When I plasti-gaged it, it measured good...easily within the clearance tolerance. But there was a slight bit of scoring on that bearing journal. Now I wish I would have ground that journal on the crankshaft. I did run some 600, then 900 then 1500 paper on it to smooth it out best I could. Since there are no over sized journal bearings available for my Kama, I guess hard chrome plating and grind back to size would be the solution?
Save that for next major service.
For the time being I'll keep a very close eye on it. With everything I've learned, I'm not afraid to do it again. The total cost for doing everything myself and only buying parts was minimal. For the next time, I'd have to send that crank out though. I have no means to do it here in the barn.
/ Engine Overhaul Kama 554 #84
Hi Rob,
Just to be sure that the oil pressure reading you have is correct, I would double check that pressure. If you have a mechanical pressure gauge, connect it to see what readings you get and compare - you wouldn't be the first guy to have a transducer to fail and give you false readings. With a bit of luck you will find that the transducer has gone and needs replacing - a lot cheaper and faster than the rebuild:D:D:D
I would also check the pressure adjusting valve for the lube oil. I know on my tractor there is a pressure adjusting valve to adjust the main oil pressure - right by the regulator on my engine. It could be the spring in that is starting to fail in it and needs to be replaced - again a lot cheaper.
Cheers
Jim
/ Engine Overhaul Kama 554 #85
Jim is right on the money with that comment. The spring may have lost a bit of it's spring tension, and a slight adjustment will put you back up in pressure. The rule of thumb is 10psi per 1000 rpms. I think you maybe ok. Plus the rod never "hammered" so a slight thunking, caught right away, me thinks no damage, or measurable wear. Glad it's purrrrrrrrring for you Rob. :D
/ Engine Overhaul Kama 554 #86
I agree gas engines the rule is 7 psi per 1000 rpm, so not sure if the diesel is more or not?
I have same problem in my old cougar after the harmonic balancer was thrown in the middle of the night driving from South Dakota to Kansas, I was pulling the boat heading home in Nebraska corn field, I had to keep going back then no cell phones. ended up wearing the rear main bearings... lost oil pressure after warming up from then on... warm pil pressure is/was only about 35psi Bearing was worn into the copper but no crank scoring. I had to put it back together that way as I had to get the car moving out of the shop they closed it on me, (military support auto shop) base closed the shop completely for lack of interest... I was in that shop probably 40 times in the 2 years I was there. I pulled front clip off engine ^& trans out, rebuilt front suspension and painted frame rails inner fenders all suspension parts after sandblasting them all. and when I pulled the engine apart they said I had to put it back together by Friday as it was the shops last day. the car was still in pieces... :( This was on a Tuesday after work... I had heads off & apart porting & polishing them long with the new alum intake. had full Elderbrock kit/system setup for it. I pulled the main caps to find well polished journals chamfered already & crank was marked .01 under. I didnt know and the bearings I had ordered ahead of time were too large... had to put it back together with the old bearings. left the rest of the bottom end alone but got all the top end done new cam & lifters & rollers into the ported & polished heads.
still ran great but the plasti-gauge told me my rear main was out to max spec. I just didnt have the time to re-assemble engine & front of car in 3 days..
Mark
Guys,
I do have a mechanical oil pressure gage.
It was installed earlier this/last year when the OEM gage stopped working. Only to find out it was not grounded correctly. You can see both the dash OEM gage and the mechanical gage in that first photo. I decided to take another set of photos after my last post.
The engine started right away and ran very smooth.
At first, the oil pressure was OK ... close to 50psi. So I don't think I need to adjust the oil pump. It should be set ok as is. After I let the motor warm up at low rpm, I ran it at medium and high rpm again and I snapped these photos below. The medium rpm photo is after about 15 minutes. The high rpm photo is after 25/30 minutes.
BTW, the engine runs great and easily reved past the green "rated speed" on the tach.
This engine is rated to make 55hp @ 2300rpm, so I figure it's getting all of that or close to 60 @ 2400rpm. Generally I don't ever run the rpm that high since I don't need all that hp. I usually work the tractor at 1800 up to maybe 2000 rpm. 1800rpm is about 150rpm over the max torque (made at 1650), so if it bogs at all, it surges back to 1800 as the max torque kicks in.
You can see the rev meter, the temperature gage is near 78C and the oil pressure on both gages.
The OEM gage has a "green" range which I presume is acceptable oil pressure. The readings are confirmed with the mechanical gage. At higher rpm, and when the engine was completely warm, the oil pressure dropped to 35psi? But it's still well in the "green" zone on the OEM oil pressure gage.
Later I ran the tractor for about 1-1/2hrs dragging my 1000lb boxblade and graded the road.
Towards the end, the oil pressure dropped even further down ... close to 20psi, but never going out of the "green zone" on the OEM gage. Still, it scared the crap out of me. With that in mind, I think the oil gages and oil pump are ok. I think I need to fix that one bearing journal because I don't remember the oil pressure ever getting that low since I heard that "bang".
What should I do?
Could I remove the crank shaft and send it out to be reground? Would they do just the one journal or would they end up doing them all to "balance" things out?
Are there over-sized journal bearings (smaller ID to fit a re-ground journal) available? Or would I need to have the journal ground down, then hard chrome plated, then re-ground to size again?
Or will I have to buy a new crank shaft and new bearings for everything?
Chip, do you have one?
I think the top end is alright, except I might balance the pistons and connecting rods for weight.
Need help here... I don't want to run it like it is.
/ Engine Overhaul Kama 554 #88
Looks like the fuel gage is trying to tell you something.
/ Engine Overhaul Kama 554 #89
Pg2 of your engine manual shows the 495T output rating is 44.1KW @ 2500 RPM. That green mark on the tach just indicates the engine RPMs necessary to produce the correct number of turns at the PTO. I guess it's just the way the linkage is designed. Cuz I too still have quite a bit of throttle left at that point. I get about 2650 outa mine. Comes in handy to be able to get more throttle when the mower gets bogged down.
//greg//
/ Engine Overhaul Kama 554 #90
Pg2 of your engine manual reflects the 495T output rating as 44.1KW @ 2500 RPM. So your 60hp guess is pretty close. That green mark however, just indicates the engine RPMs necessary to produce the correct number of turns at the PTO.
I guess it's just the way the linkage is designed, because I too still have quite a bit of throttle left at PTO revs. Wide open, I can get about 2650 outa mine. I like the capability to have reserve power underfoot when the mower starts to bog down.
//greg//
/ Engine Overhaul Kama 554 #91
Hi Rob,
I would still be inclined to look at the ajusting arrangement for the oil pressure - it isn't going to cost you much at all. First I would try adjusting the pressure up using the adjusting screw and locknut. When the engine is warm and the oil pressure down to whatever, then try increasing the pressure a bit and see what happens. Usually screwing in tightens the spring which in turn increases the pressure.
If that doesn't work or do the job, take the spring out and then check the valve itself - it could have a damaged seat on the valve or, the seat that the valve sits on could be damaged or might just need cleaning up with an end reamer or similar tool. Last but not least, the spring could be weakening or giving false reading when the oil is warm - so replace it with a new one. Another real cheap check is to put a washer behind the spring and replace and see what happens without playing with adjustments.
I would expect the pressure adjustment may have changed - for whatever reason. As long as you can get say 40psi when the oil is hot, you should be fine.
Often adjustment will do that - and it is free. Better still adjust up and down so you can really see what is happening, it will help.
On the old JD450 I rebuilt - before the rebuild, the oild would drop to about 25 psi after everything was hot. After the rebuild and replacing both the spring and valve, the oil pressure stays at around 45 psi when hot - which is more like it is supposed to do.
Don't go worrying about the rebuild if it ain't necessary - check the other variables first. My take is you just need to adjust the pressure up maybe 20 ppsi using spring and ajusting screw. Run until hoot and then see waht pressure you have. Cold oil can be very deceiving and throws a person out - it is the hot oil pressure you need to adjust.
HTH
Jim
/ Engine Overhaul Kama 554 #92
Hi Rob,
HTH
Jim
Rob,
I forgot to mention that there should be an oil pressure adjuster on the engine oil filter housing - at least that is where my one is, yours might be different. But you do need to be sure that you are getting proper pressure when the engine oil is good and hot. You will also need to determine an engine speed that you would use as a referens - 1800 rpm, 2300rpm etc. That will give validity to what you are doing and ensure the correct pressure for a given RPM.
Others have said 10 psi / 1000 rpm. So given those figures 25psi is acceptable at 2300rpm. I would be inclined to adjust the oil to about 40 psi for 2300 rpm hot. Others my disagree, but if they do they will usually give another figure that they consider right.
HTH
Jim
/ Engine Overhaul Kama 554 #93
I think the actual engine specs (FeiDong manual, pages 7-8) should take precedence.
  • engine idle (hot) - minimum 49 KPa (7.1 psi)
  • 2500 rpm (cold) - not more than 450 KPa (65 psi)
  • 2500 rpm (hot) - 250 KPa (36 psi)
  • Oil pressure adjustment procedure (in semi-coherent Chinglish) is on page 21.
They define "hot" as oil not to exceed 100C, and/or coolant not to exceed 95C (ideally ~80C)
//greg//
/ Engine Overhaul Kama 554 #94
From my experience engine oil pressure is a function of design. When I raced sports cars, my Alfa Romeo never ran oil pressure above 45 lbs, even at over 9000 rpm. The sump held 12 quarts and the pump sent a high volume of oil into the system. I had a friend with a Mini that had a 4 quart sump and if his oil pressure fell below 90 lbs he would spin bearings.
I guess I don't understand how a number like 10 lbs per 1000rpm can work for all applications.
/ Engine Overhaul Kama 554 #95
I agree, which is why I cited the FD395/495 engine manual.
Case in point: oil pressure in a used 3/4 ton Chevy I bought several years ago had me concerned, until I looked up the numbers for that particular 350. Believe it or not, that particular 350 is spec'd to only run
6 psi @ 1000 rpm,
16 psi @ 2000, and
24 psi @ 4000
//greg//
/ Engine Overhaul Kama 554 #96
10/1000 is just a general rule of thumb. My 911 engine at idle has about 15psi with M1. If you just blip the throttle it jumps right up to 60psi.
I think your journal is still OK Rob. The plastic gauge material I believe confirms this from your photos.
I would first check if there is any adjustment for the oil pressure relief, either at the filter, or in the sump just off the pump, as others have recomended.
I shimmed mine in the International backhoe BD154 engine with a 0.100" shim, and installed new oil pump gears. This is after finding by a lower end inspection the center connecting rod bearings were down to the copper after purchasing. The journals when miced were worn 0.0015". My oil pressure at 2000 rpm went from 30psi, to 45psi. At operating temperture, after before mentioned work was performed.
Did you mic the backlash in your pump gears? Mine were speced at 0.020" max clearance between teeth. Hence new gears installed.
I use Rotella std. Dino diesel 15w-40 oil in the old hoe.
There were no 0.001" oversize bearing available, so I installed a fresh new std set. And polished the journals while the crank was still in the engine like you did.
Then shimmed the oil pump relief by my engine machinist buddy's recomendation. He has much more experience than I.
I haven't had one moments trouble with the old hoe engine since, and that was 21 years ago. Like everything I've owned, I've run the ever living snott out of it. Not a peep of trouble, or knock.
My old connecting rod bearings were down to the copper, although no knocking wa heard.
Also I've found that Mobil fully synthetic engine oil holds 10psi more after complete warm up at above idle running rpms. This is by the gauges in the Porsche. Break in on regular dino oil, then switch to full syn M1.
Good advice guys,
I will look into adjusting the oil pump then.
It is, after all, going to be easy to check ... a lot easier than tearing the motor all apart again. I have Wes here this weekend so I'll be spending time goofing off with him. Plus I'll have time to cool down a bit over this because I was so dang disappointed about not fixing everything. I'll report back later next week. If I have questions (more than likely) where the the adjustments on my Kama are, I will ask.
Thanks again,
Rob-
I have an after market oil filter unit which takes a spin-on Baldwin filter.
It was a "bolt on" unit. any idea if I can adjust the oil pressure using that?
Here's a photo of it.
Rob-
/ Engine Overhaul Kama 554 #99
No fact, just supposition. But given that American spin-on filters are almost universally presumed to have a built-in bypass valve, good chance those hex heads on the left side have something to do with oil pressure..
I was thinking recently of installing that same filter head on my KM454, but lost the link to the website that sells that device. Do you remember who makes and/or sells that thing?
//greg//
/ Engine Overhaul Kama 554 #100
Rob-
Hi Rob,
It sure looks lik the adjustment to me. The cap nut should be removed and that will expose a screw (aften slotted, but could be an allen screw) with a lock nut. Slacken the lock nut off and then turn the adjusting screw in say 1/2 turn. Lock in place and then run your engine and see what the pressure change is - keeping a good eye on the pressure just to be sure. Usually screw in increases pressure and screw out decreases pressure.
One other thing worth checking is to take out the regulating vale to check the condition of the spring and the valve seat and valve. If vale seat/valve is damaged, it will register a lower pressure as the valve does not close properly - ie leaks a bit - same if a bit of debris becomes lodged under valve.. If valve seat and valve are in good condition and the spring good, then probably all that is needed is an adjustment.
HTH
Jim
2018 Chevrolet Tahoe SUV (A64194)
2018 Chevrolet...
JOHN DEERE 5403 TRACTOR (A65643)
JOHN DEERE 5403...
2019 Mirage 20' x 8.5'  Enclosed Trailer (A62613)
2019 Mirage 20' x...
2000 INTERNATIONAL 9200 DAY CAB (INOPERABLE) (A65643)
2000 INTERNATIONAL...
New/Unused ATS Welding Machine (A65583)
New/Unused ATS...
Wood Fence Post (A62613)
Wood Fence Post...
