Engine Oil
/ Engine Oil #1
JME81
New England
Kubota LX2610HSDC
The manual says if between 14 degrees and 77 that I can use SAE 20 10W-30 & 15W-40.
Living in New England, the temperatures are below and above those ranges. I'm an AMSOIL guy and would like to use their oil but am not sure which to go with. Any suggestions? LX2610.
/ Engine Oil #2
I use their 0w40 in my diesels, and 0w30 in my road vehicles.
/ Engine Oil #3
I've M1 0w30 European diesel rated oil in both the Kubota B2601 and the Isuzu generator driver. VW TDIs are probably in the millions running around with 5w30 diesel oil.
/ Engine Oil
I am not an oil expert, for my Truck, Toyota says to use 0W-20 so I put in AMSOIL's 0W-20.
Why the variance here for the tractor?
/ Engine Oil #6
put in some 0W-40 of 5W40 if you operate it during the winter, Thats what I put in mine, and it calls for 10w-30 ... as long as it is diesel engine oil for a diesel engine and your operating temperature are within the specific oil temperature chart you are good.
/ Engine Oil #7
degrees Fahrenheit?? the operating temperature of the 15W-40 is way more then 77degree F ....15W-40 temperture chart is from -31 to 104 degree F
/ Engine Oil
Fahrenheit
/ Engine Oil #9
why not a full synthetic diesel rated 5/40 to cover your bases?
/ Engine Oil #10
Fahrenheit
I see, they went pretty conservative on the temperature but its good. You can use anything between these 10w-30, 5W-30, 0w-30, 0w-40 or 5w-40 (even if not listed). If you only change your oil once a year and have extreme flux of temperature, go with the 0W-40 of even 5W-40 you have the best of both worlds. I personally always want the last number to be 40 in a diesel engine I use 0W-40 despite its price because I am in the same situation you are, having summer temperature in the 40 degrees Celsius and -30 degree Celsius in the winter. Many folks say the internal temperature doesn't go over 30 degrees Celsius regardless of the external temperature they may have a point and since your manual say you can put 0W-30 you can.
fist number = cold temperature viscosity coefficient and Last number = Hot temperature viscosity coefficient
/ Engine Oil #12
I like a 5w-40 synthetic year round, I'm using some of this Heavy-Duty Synthetic Diesel Oil 5W-40
/ Engine Oil #13
All oils operate at 210-230 F as set by about 190 F thermostat in the coolant. Don't have a clue what those upper temps on the oil charts mean. Think they're for air cooled engines.
/ Engine Oil #15
I do believe that those are the expected ambient air temperatures.
/ Engine Oil #16
I'm going on 14 years of owing 3 brand new Kubotas and just use Kubota brand 10W30 for my climate as advised in the OE manual. Heck, those Kubotas are going to be around a lot longer than me.
Cheers,
Mike
/ Engine Oil #17
My Bobcat has the same recommendations for those temperatures. It also says you can run the full synthetic 5w-40 that covers all temps.
/ Engine Oil #18
I'm using Amsoil synthetic 15w-40 all year around here.
Temps range from +105F in the summer to -45F in the winter.
/ Engine Oil #19
Doesn't make any difference. All oils operate at 210-230 F irregardless of outside temperature. Outside temperature has no effect on the hot oil's performance. Cold does.
/ Engine Oil #20
That is still the ambient temperature range that the engine is expected to operate in.
For most the low temp rating is the important point, unless your out in the desert in July.
New 40' Double side door Container (A62679)
New 40' Double...
2018 BOBCAT E50 EXCAVATOR (A65053)
2018 BOBCAT E50...
New/Unused Landhonor 8ft x 10ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
2012 T/A Frac Blender Trailer (A64194)
2012 T/A Frac...
2018 JOHN DEERE 650K LGP CRAWLER DOZER (A64279)
2018 JOHN DEERE...
2250' of 5" Tile (A66408)
2250' of 5" Tile...
