Sodo
Elite Member
- Joined
- Apr 21, 2012
- Messages
- 3,321
- Location
- Cascade Mtns of WA state
- Tractor
- Kubota B-series & Mini Excavator
I disagree.
There are measurable differences in pour point and flow characteristics between different grade oils.
You should be able to take a sae 30, 15w40 and 5w40 into a lab, and in a blind test, be able to show which oil is which due to pour and flow characteristics and viscosity index.
The differences are quite detectable, quantifiable, and measureable.
You are right. You don't need a lab to see those differences. And the color can be visibly different too. I don't think they have (measurable) effects on the longevity of a tractor if it's changed per the hours specified in the manual. If you are using a tractor in extreme conditions, that's a little different. Put-put-put-ing over to lift a few bags of concrete from time to time, or lawn mowing does not require special oil. I'd bias towards using the weight specified in the manual though.
