Engine Noise
   / Engine Noise #1
markh1
Story City, IA
2003 Jinma 284LE Y385T
My engine started making a clanking noise (the best I can describe it). I don't know what a broken rod sounds like but I thought that might be a possibility. It's a Jinma 284 LE and it has 475 hours on it. Ran fine until this happened.
Thanks,
Mark
   / Engine Noise #2
First, are you sure it's the engine? Could it be a fan blade, a loose alternator, radiator, or cowl? Second, we need more than "clanking". Is the engine smoking? Overheating? Does it do it in gear? In neutral? When the clutch is pushed in? when the clutch is released?
//greg//
   / Engine Noise #3
Clanking noise? Have you determined more specifically where in/on the engine that noise is coming from? Put a stethoscope on it or just opened the bonnet and listened carefully to try to isolate the source of the noise? Does the engine still run okay? Is it developing normal power, or is it low in power? Have you done a visual check to determine if there is anything visibly loose that could be making the noise, such as alternator, water pump, etc? How does the exhaust look - white smoke, grey smoke, black smoke?
I'm asking all these questions because just saying there is a clanking noise is impossibly vague. We have to have something more to go on to begin to determine where to look. It could be a thrown rod (unlikely, as those make a god-awful racket and then the engine dies), a bent pushrod, a broken lifter spring, a loose exhaust manifold, etc, etc, etc.
Some more background info would be helpful, too. Was it properly serviced/set up when you first got it - clutch adjusted, fluids changed, etc? Was the valve lash set at 50 hrs? Head re-torqued? Did it get all the required fluid changes at the suggested intervals? Have you checked the engine oil for water contamination? Checked the radiator coolant for oil contamination? Are the fluid levels all where they should be?
What were you doing with the tractor at the exact time it suddenly began making this "clanking" noise?
If you can supply the answers to most of these questions then someone here can make an educated guess as to where you should investigate further to determine what is going on. Without those answers no one could possibly guess, except by wild-assed luck, unless they have ESP.
   / Engine Noise #4
I see that Greg and I have the same concerns - give us the information and we can take it from there.
   / Engine Noise
It did not over heat, normal oil pressure,, fluid levels ok, maintenence and fluids up to date. I have not listened to it or started it because it sounded like it could be doing some serious damage. It isn't something external I listened long enough for that much info. When I increased the engine rpm a litte at first the speed at which the noise reocurred increased with the engine rprm's. I got off the tractor and listened before turning it off. I have not checked the radiator yet.
Mark
   / Engine Noise #6
I could also be a sticking fuel injector,which makes a sound very similier to a rod knocking.On top of each fuel injector is a hose 13mm bolt with the return fuel line. While the tractor is running,loosen that bolt 1-injector at a time to see if the tractor rpm changes,or any engine sound change at all. Most of the time the one that does not make any change to rpm or engine sound is the problem or clogged injector.
Tommt
AffordableTractor Sales
"Your Jinma Parts Superstore"
Home of compact Jinma, Foton, and Koyker Tractors and Parts, Wood Chippers, Backhoes - Affordable Tractor Sales Company
   / Engine Noise #7
Tommt
I totally agree, in part. But I'm curious, how will loosening the fuel return line have any effect on engine performance?
   / Engine Noise #8
I think the process is to deny full fuel pressure to each injector, one at a time. When rpms show little or no response to an isolated injector, it should point to that one injector as having a problem.
   / Engine Noise #9
Totally agree, but what does the return line have to do with it? Wouldn't you want to slightly loosen the high pressure supply line instead?
(INOP) JOHN DEERE 730 CRAWLER TRACTOR (A51243)
(INOP) JOHN DEERE...
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
2004 TRAILKING 101" X 53' STEP DECK TRAILER (A50459)
2004 TRAILKING...
New/Unused 7ft 20 Drawer Stainless Steel Workbench (A51573)
New/Unused 7ft 20...
