Engine Noise
/ Engine Noise
I removed the input and output fuel lines to the injectors and removed the 2 bolts and the piece it holds down. I'm not sure how to take them out now. Could somebody help me out?
Mark
/ Engine Noise #22
Mark
Simply pull them straight out while rotating. They are not threaded in. You may need a heel (crowfoot) bar if they're carboned in pretty bad. You can also try a few drops of penetrant around the injector body.
/ Engine Noise
I got them out. I thought they just pulled out but the first one was stuck and I wanted to make sure I wasn't missing anything before I applied a little force. One just pulled out easily. Thanks for the help.
Mark
/ Engine Noise
Had the injectors checked and 2 opened at 2000 psi and 1 was 0. Will order 1 and post the results when I get it back in. I hope that's the problem.
Mark
/ Engine Noise #26
Mark
They found the dribbler! Good for you. :thumbsup:
Should run like a champ now.
Curious how much they charged for the testing if you don't mind. :)
/ Engine Noise
He said the 2 had a good pattern at 2000 psi and the bad 1 was a straight stream holding no pressure. He said normal for their tractors is 3000 to 3500 psi. I dropped them off at a John Deere dealership and he said it didn't take long so he didn't charge me anything. I was suprised because I have only been in there 2 or 3 times and I know they didn't know me. Will probably be 3 or 4 days before I get the new injector. No mail today so will go out tomorrow. Didn't want to pay for overnight delivery.
Is there a torque setting for the injectors?
Thanks to all for the advice and help
Mark
/ Engine Noise
The injector I ordered came today. I installed it and the tractor is back up and running. Thanks for the help.
Mark
2011 Ford E-250 Cargo Van (A64556)
2011 Ford E-250...
2018 MACK LR633 6X4 T/A GARBAGE TRUCK (A66091)
2018 MACK LR633...
2018 Ford Explorer AWD SUV (A64557)
2018 Ford Explorer...
2007 VOLVO VHD QUAD/A VACUUM TRUCK (A67148)
2007 VOLVO VHD...
2022 Mac Trailers 48ft. T/A Walking Floor Trailer (A64556)
2022 Mac Trailers...
2022 EZ-GO ELITE...
