Engine leaking oil
/ Engine leaking oil #1
Karlibob
2025 Summit TX25H
I just purchased a TX25H this week. I’m happy with the performance but I have had a couple of issues. The first was the 3 point hitch would not operate. I contacted Summit and they were quick to help with a solution. The travel lock valve was frozen. I had to remove the cover plate who’s was removing the know, removing 2 bolts and 3 plastic push pins. I used a pair of pliers to rock the flexible line back and forth and it freed up and the 3 point dropped down and is now working. The rep thought that was the issue up front and turns out he was right. Second issue is that I have a drip under the engine and over the last 24 hours it has turned into a small puddle. Has anyone experienced this?
Typos above.
I had to remove the cover plate by removing the valve knob and then I removed the bolts and push pins.
I’m not sure why the above text happened the way it did.
/ Engine leaking oil #3
I thought I had an oil leak, and it was the dipstick rubber plug not sitting in the dipstick tube all the way. Oil splatters out after a little operation and gets on the bottom of the engine, and starts dripping. I would check that first.
-Andrew
I will check that, but I went out to start it today and the battery was dead. I tried jumping it but to no avail. This has happened twice now. Im taking the battery out and going to running's tomorrow. This is getting old. I will check the dip stick tomorrow.
Thanks Amfab
Found out yesterday that it's the pinion oil seal on the front. The dipstick would have been great.
/ Engine leaking oil #6
Welcome to TBN.
Hopefully your leak is covered under warranty (with it being this new it sure should be), what is your dealer telling you?
/ Engine leaking oil #7
oh, sorry it wasn't simple
It is covered.
EZ Flow Mod. 300 Gravity Wagon (A66408)
EZ Flow Mod. 300...
Farmall Cub Tractor (A62613)
Farmall Cub...
429860 (A61166)
429860 (A61166)
New/Unused AGROTK 72in Quick Attach Brush Cutter (A65583)
New/Unused AGROTK...
Kubota V3600-T-E2 Turbo Diesel Engine - 3.6L - 84 HP - 2018 - Tier 2 - Pump Takeout (A63689)
Kubota V3600-T-E2...
Case TV380 (A62177)
Case TV380 (A62177)
