Engine detailing
/ Engine detailing #1
flusher
Super Member
Sacramento
Getting old. Sold the ranch. Sold the tractors. Moved back to the city.
My recently purchased mid-60s MF-135 diesel needs a real good engine cleaning (exterior) so I can service the fuel system and generally get the tractor looking better.
Any suggestions on how to do this efficiently (favorite degreasers, solvents, cleaners, power washers, procedures, hand tools, etc)?
Am debating whether to hit the grease with a power washer or steam jenny. There's apparently a division of opinion on whether you do more harm than good using these aggressive cleaning approaches (water in the electrical system, etc). Anybody care to venture an opinion or relate experiences.
/ Engine detailing #2
I just finished rebuilding the carb on my old Ford 3000, and like you, had a huge amount of buildup to work through. Everything had about 1/8" of grease/dust/seed surrounding it. I found that compressed air did a surprisingly good job of getting most of it off. It will at least get the worst of it off so parts needing more attention can be removed and cleaned separately. I used Chem Dip for the stubborn areas on the carb body, but I wouldn't spray that on the engine. Make sure you wear safety glasses or goggles, and I tried to direct most of the dirt toward the floor when possible.
/ Engine detailing #3
I'd just go with a pressure washer and some dish detergent. I have been using power washers on engines for 40 years now and have never had any problems. [ even with the old distributor and and points type ignition ]
/ Engine detailing #4
I pressure wash my tractors when ever they get dirty enough to need it. Never had any issues because of that. I'm starting to restore an old MF 50 that was my fathers. Last time it was clean was probably 1957. I pressure washed it. Then I took to it with wire brush, paint scraper, screwdriver, and a blow gun (wear eye protection). Then a good degreaser and pressure wash again. Don't spray directly into any ignition components or the carb.
/ Engine detailing #5
Mornin Flusher,
All good suggestions !!! I used some Purple Power available from your local NAPA dealer that works pretty good. Pressure washer can remove alot of the crud. The rest will be all elbow grease :)
/ Engine detailing #6
__________________
Code:
How do you get that elbow grease off?:D
/ Engine detailing #7
__________________
Code:
Must have missed that in the manual. How often do you need to grease elbows?
/ Engine detailing #8
Is that dino elbow grease.. or synthetic elbow grease?
Soundguy
__________________
Code:
3pt Counter Weight (A64127)
3pt Counter Weight...
2014 CATERPILLAR 573C FELLER BUNCHER (A62129)
2014 CATERPILLAR...
Prime 283 (A64126)
Prime 283 (A64126)
WEATHERHEAD COLL-O-CRIMP T450-1 HOSE CRIMPER (A64276)
WEATHERHEAD...
New/Unused Landhonor 12V Diesel Pump (A65583)
New/Unused...
2018 Dodge 5500 Bucket Truck 4WD (A63689)
2018 Dodge 5500...
