engine change
/ engine change #1
treebee
norfolk
kubota
I have a L225dt age about 1976, been told the crank is not salvageble new ones not available and it alsos needs liners etc. Bit of a mess. Been offerd a "v" series engine which is bigger hp (35) and 4 cylinder.
I know the L325dt had a 4 cylinder 35hp engine and used the same gearbox etc
Anyone know anything about compatabily of the "L" and "v" series?
/ engine change #2
I don't know if that engine would be compatible with your tractor, but I suspect a 4-cylinder engine may (but not necessarily) require a longer chassis.
In any event, Kubota label their 3-cylinder engines as "D" series and their 4-cylinder engines as "V" series. (I read somewhere that that is based on German terminology.) For example, a D1100 series is 3-cylinder, 1.1 litres and a V1500 series is 4-cylinder, 1.5 litres, with various versions in each series, e.g V1505.
The "L" series (as you know) is a tractor label, as is "B", "M", etc. An "L" model tractor could have a "D" or a "V" engine, depending on whether it was 3- or 4-cylinder.
/ engine change #3
Hi Treebee,
I know this is an old thread - but I find myself in nearly exactly the same situation - except my crankshaft is broken. I have a L1501, but someone before I bought it has replaced the engine with a 3 cylinder, probably a D1100. Having trouble sourcing a new one (as you found). Just wondering what you ended up doing - could you get a replacement engine, or what happened?
Cheers,
2015 Ford F-250 Knapheide Service Truck (A64556)
2015 Ford F-250...
2022 EZ-GO ELITE...
HARDEE LR50160 DITCH BANK MOWER (A64278)
HARDEE LR50160...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2020 Chevrolet Tahoe SUV (A64194)
2020 Chevrolet...
2016 Land Rover Discovery Sport SUV (A61574)
2016 Land Rover...
