[emoji637] ton Ram-single vs dual wheel?
   / ton Ram-single vs dual wheel? #31
That’s true. But you probably wouldn’t do that. I pointed out the pros and cons. That’s all.
Have done it on more than one occasion. Flat tire and no spare? Have run with 5 to get somewhere off the road. Trailer flat have used “extra” truck tire to get somewhere to find a tire. Mud, like sand, air down a little. Snow add ballast. No noticeable problems with either
   / ton Ram-single vs dual wheel? #32
If I decided that I was OK with the width and ride quality of a dually, I would skip the 3500s and go straight to 4500s. The Ford F-450 is a very popular option. Reason being is you get MUCH better turning radius which takes a lot of the pain out of driving a dually. You also get heavier rated axles and brakes.
“Friends don’t let friends drive Fords” 😋
   / ton Ram-single vs dual wheel? #33
I had a 2014 F350 shorted SRW. Pull a 14.5k "5th wheel" (now gooseneck) 35' toy hauler and a 22' bumper pull tilting deck trailer. 4k of trailer & 6k of tractor & implements on it, so usually 10k. 2.5k lbs of pin weight on the gooseneck, 800-1.4k on the Weighsafe bumper pull hitch depending on the load & ballance.I've been hauling both trailers this summer with a rental for reasons. Had a Ford dually for a couple months & a new Chevy dually this month. All diesels. I really can't tell a difference in stability dually vs single. The extra length & width is noticable in parking lots.
I'd assume the extra tires & stability show up with heavier loads. I'm likely to look at a long bed as a next truck for more room for camping junk, but won't be looking at a dually. Just extra cost & maintenance for my use case with no direct benefit.
The only thing I could think of would be loosing a tire on the rear & the extra getting me to a safe spot to change it.
Very different story if you are puling loads near the limit of the dualies, but my loads are always under the rating of the singles.
   / ton Ram-single vs dual wheel? #34
In case you are wondering, this is what a basically max GVWR load looked like this weekend on my little SRW truck. The whole thing weighed about 23,500 coming out of the scale house. 10K truck and 14K trailer. I absolutely would not want to pull much more than this with a single tire. My best guess for trailer weight is right around 15,000 lbs.
   / ton Ram-single vs dual wheel? #35
View attachment 4080757View attachment 4080759View attachment 4080760
Done that with a F150 for several 40 mile trips before. Well, close. 21000lbs
   / ton Ram-single vs dual wheel? #36
Yep, I know that feeling. That is why I switched from a 2500HD to a 3500HD DRW. I could have pulled all my trailers with the 2500HD, but I sure feel better with the 3500HD DRW. My wife said get what I needed to feel safe, so I did.
I try to limit my loads based on weight per yard to avoid going overweight. Means only hauling 4 yards of recycled asphalt or rock at 2600# per yard, instead of 6 yards which easily fits. Even 6 yards of topsoil at 2000# per yard dry, which fits fine in the trailer, puts me just over the limit of 11,250# that is the trailer cargo load limit. The new ram lift trailer handles it, no problem. I also switched to G rated tires on the trailer for extra security.
   / ton Ram-single vs dual wheel? #38
I've had them all, including full size Toyotas. If I had to pick, Ram would be #1 and Ford would be #2. GM wouldn't even make the list, they'd be on injury reserve.
And I am just the opposite, you cannot run fast enough to GIVE me a Ram or a Ford.
   / ton Ram-single vs dual wheel? #39
   / ton Ram-single vs dual wheel? #40
I have owned no Rams but the company I worked for had them.
2013 BRENNER 250BBL TRI-AXLE ALUMINUM TANK TRAILER (A53843)
2013 BRENNER...
John Deere 6105E Tractor, 105HP, 4WD, Suspension Seat, A/C, 3 Rear Remotes (A53473)
John Deere 6105E...
2013 FREIGHTLINER BUSINESS CLASS M2 VACUUM TRUCK (A51406)
2013 FREIGHTLINER...
2017 JOHN DEERE 350G LC EXCAVATOR (A52705)
2017 JOHN DEERE...
3 Ergonomic Computer Keyboard Trays (A51695)
3 Ergonomic...
Harrell 3605 (A50123)
