[emoji637] ton Ram-single vs dual wheel?
   / ton Ram-single vs dual wheel? #61
air ride, power steering, ABS, automatic, A/C
How else would a driver be able to hang their foot out the window at 65? Hard to wear flip-flops and use that 3rd pedal.
Have you ever tried to jack up a trailer that’s 6” under the hitch? Aside from the obvious better ride quality an air ride truck makes hooking up much easier. An air ride truck requires less maintenance than springs. It’s hard enough get a big truck in a small yard with power steering. Power steering is basically a necessity. ABS is required by the government regardless of how well it does it doesn’t work. Nobody is making you use the ac but most drivers would quite and work for a different company that has ac. The automatic transmission is again less maintenance. If you’re stuck in hard mode for no apparent reason why don’t you just use a wagon?
   / ton Ram-single vs dual wheel? #62
This is what I normally drive, plus a 53' tail behind it ... Parking any "pickup' srw/drw short/long bed is a breeze!
Only reason I'd not keep a free new truck is in Missouri is taxes! Sales tax to register, plus we have "personal property tax" which is a tax on the value of your personal property like vehicles, tractors/equipment/attachments ,cattle, hay for sale ... All based on ownership on January 1st
My 2018 RAM 1500 is around $550 a year ... Goes down slightly every year, based on MSRP ...
Wow! We've got plenty of taxes here - for sure - but not quite as far as that personal property tax! Don't give our politicians any new ideas!!!
   / ton Ram-single vs dual wheel? #63
It's just a different way to get money ... On my 11 acres of vacant land I paid $16 last year in property tax!
   / ton Ram-single vs dual wheel? #64
I love the automatic in my IH-7500.
Hopefully, no more manuals for me. Life’s too short and I got enough work to do!
   / ton Ram-single vs dual wheel? #65
You said find tires, indicating a change from stock. Changing wheels/tires is a pretty common mod.
Just to “keep it real”, those 19.5” rims & tires ride mighty stiff. It would make the ride quality much worse.
Its also really expensive.
   / ton Ram-single vs dual wheel? #66
Apparently I left you an opening and you jumped on it; I was referring to stock tires that come on the vehicle.
It's not worth arguing about anyway.
   / ton Ram-single vs dual wheel? #67
Once again wishing I had a dually. It pulled just fine, but more sag than I wanted and I sure would have been more comfortable with a couple extra tires, just in case. This is the top end of what I typically tow on a trailer. It was heavy, full of tools and product.
   / ton Ram-single vs dual wheel? #68
That load would have been fine with a gooseneck and your SRW. But yes, the service truck was probably 12k+, so too much for the combo.
   / ton Ram-single vs dual wheel? #69
If they were to impose a personal property tax here, I'd be moving.
   / ton Ram-single vs dual wheel? #70
They do that here. The property tax in my county is among the cheapest in the nation but I did have to pay like $200 for personal property. You’re supposed to fill out a form of everything I own but I never do. They forced assessed value at like $50,000 and the $200 tax was for that much.
JOHN DEERE 3020 TRACTOR (A54756)
JOHN DEERE 3020...
2014 Ram 1500 4x4 Crew Cab Pickup Truck (A53422)
2014 Ram 1500 4x4...
SOMERO S-222 LASER SCREED (A52707)
SOMERO S-222 LASER...
Pratt 8.5ft Flatbed Tilt Trailer (A55787)
Pratt 8.5ft...
2007 Ford E-450 Super Duty 16ft Portable Command Center Office Truck (A55852)
2007 Ford E-450...
2025 JMR Tree Boom Skid Steer Attachment (A53421)
2025 JMR Tree Boom...
