emax20hst how to bleed unusual fuel system
   / emax20hst how to bleed unusual fuel system #1
tucker2
Hickory,NC
Kubota L1500, Iseki TS1910,Trak King dozer
First off I have a new emsx20s & a older 2018 emax20hst, it will crank but not start, I tried to compare the two but the new one only has 1 fuel shutoff solenoid, the hst has 2 on the inj pump - why?. Anyway I am trying to bleed the system thur the inj pump but can't find information anywhere. The fuel pump has a lever & I can pump fuel using it but it's real low volume apparently this older model uses a mechanical rather than a electric pump, any help would be appreciated.
   / emax20hst how to bleed unusual fuel system #2
The hst bhas a “cold start solenoid”.. towards the bottom of the pump..it’s not a shut off solenoid..
Make sure you have fuel at the inlet of the inj pump..
Then Loosen the lines AT THE INJECTORS and crank the engine until it starts to squirt fuel at the loosened lines and tighten..
2020 CATERPILLAR 242D3 SKID STEER (A60429)
2020 CATERPILLAR...
2387 (A60432)
2387 (A60432)
2018 Kubota M5-111 (A60462)
2018 Kubota M5-111...
2011 VOLVO VNL760 SLEEPER (A59904)
2011 VOLVO VNL760...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
208735 (A60430)
208735 (A60430)
