emax20hst how to bleed unusual fuel system
   / emax20hst how to bleed unusual fuel system #1
tucker2
Hickory,NC
Kubota L1500, Iseki TS1910,Trak King dozer
First off I have a new emsx20s & a older 2018 emax20hst, it will crank but not start, I tried to compare the two but the new one only has 1 fuel shutoff solenoid, the hst has 2 on the inj pump - why?. Anyway I am trying to bleed the system thur the inj pump but can't find information anywhere. The fuel pump has a lever & I can pump fuel using it but it's real low volume apparently this older model uses a mechanical rather than a electric pump, any help would be appreciated.
   / emax20hst how to bleed unusual fuel system #2
The hst bhas a “cold start solenoid”.. towards the bottom of the pump..it’s not a shut off solenoid..
Make sure you have fuel at the inlet of the inj pump..
Then Loosen the lines AT THE INJECTORS and crank the engine until it starts to squirt fuel at the loosened lines and tighten..
2013 Chevrolet Impala Sedan (A55853)
2013 Chevrolet...
John Deere 6105E Tractor, 105HP, 4WD, Suspension Seat, A/C, 3 Rear Remotes (A55302)
John Deere 6105E...
2005 Dodge Grand Caravan Van (A55853)
2005 Dodge Grand...
2024 JOHN DEERE 35P LOT NUMBER 107 (A53084)
2024 JOHN DEERE...
2005 TerraGator 8104 (A55302)
2005 TerraGator...
Rooster Weathervane (A55853)
Rooster...
