Electronic Ignition for Gasoline tractors ( Pertronix )
   / Electronic Ignition for Gasoline tractors ( Pertronix ) #11
Had 2 tractors that ended up in my herd,---- neither ran, problem???? that electronic crap was junk! --Put both of them back to good old stock points and never looked back! That electronic crap seeeemes to work on cars because that is what is is designed for ---just dont work on ALL tractors! Too expensive and troublesome for me to have around!
His point is to many times EI is put on to cover up other issues with a worn engine. I like EI and think it has its place but I will not have it on a tractor of mine. I have had conversations with to many folks that have converted from points to EI and have been left with a sitting tractor when the EI failed. One man I spoke with last year was installing his 4th after the 3rd one had failed on a machine that he installed new wiring and made a good clean install, yet they still failed.
Anyone who can read and understand the wear on a set of points can have a very reliable ignition system. A system that if something should go wrong in the field that can generally be fixed good enough to get back to the barn with a simple screwdriver instead of being stuck in the field with a burned out part. The art of setting points ignition systems is a lost skill like so many other things now days, done right points will run for years without issue. Plus I can keep a spare set on hand and/or replace several sets of $10 points for the cost of one failed EI.
Hey John0829 ! That's to bad for your friend hopefully he has gotten his money back, As they do offer a 30 month guarantee.I run Pertronix in 3 classic automobiles ,1 of my tractors & I've installed them on a boat with a I/O I did sell the boat & the owner is a friend of mine! Not 1 failure on these apps. & my friend who bought the boat installed 1 on his Oliver 10 years ago no failures! & I've set more points than I care to remember or want to & if points where so great why is every engine manufacture no longer using them including small engines ! Also Pertronix states clearly to keep your points parts in case the Pertronix does not work with your ignition system & I will agree with You & RickB it shouldn't be used on failing or poorly maintained piece of equipment ! As the saying goes you can put lipstick on a pig but it's still a pig & I agree again with You & RickB this should not be used as a band aid.& this is a alternative to those who want E-I & not points.
Hey good for You! But You are wrong on the apps. & to make that statement is truly bias & misinformed.
   / Electronic Ignition for Gasoline tractors ( Pertronix ) #14
The only application where I've seen a Pertronix completly fail is on a pumping unit. They run 24/7 in the summer in an irrigation application and after several years one failed. I've also had to repair a Pertronix where all the magnets fell out. I found all of them inside the distributer and scotch tape held them back in place. Other than thise two instances they have been a very reliable conversion. In my less than humble opinion that sure beats setting points on a regular basis.
Zero Turn Mower (A59228)
Zero Turn Mower...
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
2017 VOLVO VNL TANDEM AXLE DAY CAB (A59575)
2017 VOLVO VNL...
2018 HYUNDAI VC2530152-JS DRY VAN TRAILER (A59575)
2018 HYUNDAI...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2007 Kenworth Tandem Axle Road Tractor (A47477)
2007 Kenworth...
