Electronic Flasher Circuit
/ Electronic Flasher Circuit
Bird - Thanks for checking! I don't ever remember seeing the flasher on my L4310, so I figured it must be pretty well buried...
/ Electronic Flasher Circuit #32
I've never seen it either, Mark, but it shows to be on the left side between the instrument panel and the fuel tank.
/ Electronic Flasher Circuit #33
Mark,
<font color=blue>Does anyone know what a Kubota flasher looks like,yes and how many
terminals it has?yes Or does anyone have any ideas on how I could make my two electronic flashers do what I
want?yes Or perhaps my two plus the OEM one?</font color=blue>
Hope this helps/w3tcompact/icons/wink.gif
That was fun /w3tcompact/icons/smile.gif The B21 flasher is a three terminal device. +12V, Ground and output. The output is a relay contact closure to +12V. Internally it is a two transistor timer controled by a resistor/capacitor network. When it times out, it pulls in a relay for a period of time controlled by the RC network. The period is independent of the lamp current, your LED lamps would work just fine. I have the internal schematic of the part. I did work up a schematic of how I would effect the functionality of your lighting system as I understand it. I'm at work and don't have a part number of the flasher available. I will send you an email later with the P/N and a description of the circuit sufficient for you to figure out that it won't work /w3tcompact/icons/wink.gif
Al
Al - Cool! /w3tcompact/icons/cool.gif But I thought Bird said his flasher had 7 connections! And I don't see how it could do what I'm wanting to do with only three wires. That's essentially like the ones I've got, it sounds. Hmmm. /w3tcompact/icons/hmm.gif I think I'll shut up and wait for your e-mail... I need to talk to you about pressure sensors anyway...
Thanks!!! /w3tcompact/icons/grin.gif
/ Electronic Flasher Circuit #35
Mark, I went back and double checked and it sure does show 7 wires connected to it. Unfortunately, the schematic is too big a sheet of paper for my scanner, and goodness knows how long it would take me to learn to scan it in sections and piece them together./w3tcompact/icons/frown.gif
/ Electronic Flasher Circuit #36
Mark,
Yep 3 wires on the B21 flasher. Now my B7500 is like Bird's 2710, 7 wires.
<font color=blue>I don't see how it could do what I'm
wanting to do with only three wires. </font color=blue>
It would be harder but I'm thinking two of the three terminal flashers. Later
SAW (still @ work).
Al
Al - <font color=blue>I'm thinking two of the three terminal flashers</font color=blue>
That's great, for two reasons: 1) I already have two 3-wire flashers (three, counting the Hella one already in the EF-5) and 2) I checked with the dealer today and the Kubota 7-wire flasher costs over $50 and change! /w3tcompact/icons/shocked.gif
/ Electronic Flasher Circuit #38
Mark, I scanned my schematic in 3 sections; thought I might learn to piece them together, but even though I thought the sizes of each section would be the same, they weren't./w3tcompact/icons/frown.gif I've played with Picture It! for a couple of hours and so far it's got me beat. I never did figure a way to put the sections together so they'd make sense./w3tcompact/icons/laugh.gif
Bird - I sure do appreciate your efforts, but you've spent way too much time on it already. I'm sure my local Kubota dealer can make a copy of it for me. I'm sorry you spent that much time on it without getting it, though - that's frustrating.
/ Electronic Flasher Circuit #40
Mark, I just thought I'd get a little practice and try to learn more about Picture It!. Well, I got a lot of practice all right; but not sure I learned anything except maybe how dense I am./w3tcompact/icons/laugh.gif
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A61307)
2023 Unverferth...
2011 Mercedes-Benz E-Class Sedan (A59231)
2011 Mercedes-Benz...
Kubota SVL75-2 (A57148)
Kubota SVL75-2...
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
2006 Freightliner Auger Truck (A61307)
2006 Freightliner...
