Electrical / romex mess
/ Electrical / romex mess #101
ive used a non contact tester for 20 years. never failed me yet. mind you i use a Fluke model, not a harbor freight model.
/ Electrical / romex mess #102
Romex is not rated for underground burial. Dangerous. But code does not prohibit romex in conduit, FYI. You haven't spoken about the amperage requirements for the water feature pump. Maybe the existing wire isnt big enough to begin with. Take the time and expense to put in conduit, wire and boxes appropriate to the installation. Dont make a poor installation worse by increasing amperage on wire not rated for the installation to begin with.
/ Electrical / romex mess #103
Can the second wire be the switch leg? Jon
That’s what I was thinking. If the hot leg was wired to the switch you would only have one cable (“Romex”) run out to the light. If someone was thinking ahead (and not stingy with the wire) it makes sense to run the hot leg all the way to the light and run a separate switch leg. That way you have hot, neutral, and ground at the “circle” and can add a receptacle (or a pump for your water feature). If not, everything in the “circle” will have to be switched and will only work with the light on.
Did you just disconnect one cable at the light or were both of them at the light? If not, could they have been spliced before you dug them up? If you just turned off power using the switch then the hot leg would still be hot from the breaker.
That makes sense with one wire dead and one still hot.
Might take a little wire tracing, but if your wire is ok, you already have power for your pump and a switch leg you can use for a new light if desired.
Makes sense, thanks! I'd probably put the light(s) on the always hot circuit with a photo eye. Then put the water feature on the switched circuit. I'd want the light always working at night no matter what I do, but only use the water feature on demand.
/ Electrical / romex mess #105
A water feature can run fine on 15 amp circuit. Have hooked many up.
/ Electrical / romex mess #106
Holy cow! Is that mains power? I recently had a new shed connected to single phase 240v at 32 amp the cables were all in orange pvc conduit buried 2ft deep with warning tape laid 6" above that before the trench was filled, also had a separate phone and computer lines in the same trench in 3/4 grey conduit 6" spacing from the mains conduit over 120ft in length and mapped on my property all done to code hear in Australia, We also have a Dial before you dig service even in some cases on private property.
I would be buying a lottery ticket if I were you, just luck you didn't put a pick or shovel through the cable.
Was that cable laid to your code?
/ Electrical / romex mess #107
I think this thread has potential. Not quite "pallets" caliber but definitely "stuck bolt".
Does need more actual pictures.
/ Electrical / romex mess #109
Probably best to call your local electrical contractor, that wire does not even look like direct bury Romex
We have a light on a pole in our driveway. Its in a center circle bordered by pavers. I want to replace the light with a water feature.
I turned power off, removed the light and pole, and found two romex lines. One was still hot (don't ask!) They are about 2 feet below current grade, and about 3 feet below what the new grade will be.
I need to move these lines as the new water feature would be sitting right on top of them. I wish they were long enough to get to an electrical box on the edge of the circle, but they are not nearly long enough. And I still need power out there for the new pump.
I know you are not supposed to put romex in conduit. Nor splice wires and have electric junction boxes underground. But I'm stumped on what else to do?
Any ideas?
First, you need to find out where the power is coming from. Are there 2 switches that operate it?
Due to liability issues have this done by a licensed Electrician to Code.
Just tie it together. Wrap a gallon zip lock bag around it. Tie the ends of bag. Insert tip of tube of silicone in one end and pump it full. You can move bag around until wire is centered. Leave it alone to cure out. Youre welcome.
Thank you. Hard to believe it took over 90 posts to get to something simple and obvious.
My electrical contractor used gallon zip lock bags for my main service panel.
Seems to work fine, but it's hard getting the panel door closed pushing against all the bags ....
1999 TRANSCRAFT FLAT BED 48FT TRAILER (A59905)
1999 TRANSCRAFT...
International 9200 (A61307)
International 9200...
SKID STEER ATTACHMENT PACKER (A58214)
SKID STEER...
2006 CATERPILLAR 304C (A58214)
2006 CATERPILLAR...
1990 21ft Center Console Fishing Boat with T/A Boat Trailer (A59231)
1990 21ft Center...
INGERSOLL RAND G25 GENERATOR (A60736)
INGERSOLL RAND G25...
