Electric switch pto
/ Electric switch pto #1
tbibbs00
Montana 5740C
I have a 5740C, the pto switch will not turn off. The tractor will not start with the pto turned on. Anyone have suggestions?
/ Electric switch pto #2
Replace the switch. Pull the wires off the switch so you can use the machine.
Thanks, Is this a common thing with the pto switch?
/ Electric switch pto #4
Try a TBN "search" with your Montana Mdl# and see if anyone else has reported simular issues.
Boone
/ Electric switch pto #5
My 2007 5740 has a dfferent problem with the PTO switch. It will not activate the Manual mode. It still functions in OFF and continuous though. I suppose I ought to get a switch on hand before I get stranded.
As a second thing to check before replacing the switch, look for wiring damage from rodents or other damage first.
/ Electric switch pto #6
I know that if the pto switch is on, the starter will not turn the motor over to start. That is a safety, that is built into the unit. The pto switch is wired into the clutch pedal switch, which in turn goes to the starter solenoid . As far as the pto not turning off, That is a new one to me. Usually, they won't engage, which is usually a wiring issue. I suppose, a switch could go bad, but haven't seen that to often. Maybe, you'll get lucky with a new switch, but I have my doubts. I'll have to check the wiring diagram, as I have not had many issues, of this kind, locally.
2004 Gator Trailer (A62679)
2004 Gator Trailer...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A63689)
PENDING SELLER...
3 Point Boom Lift (A62613)
3 Point Boom Lift...
2012 PROCCO 130BBL (A65643)
2012 PROCCO 130BBL...
1992 Kenworth T600 Semi Truck (A66285)
1992 Kenworth T600...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
