Electric switch pto
/ Electric switch pto #1
tbibbs00
Montana 5740C
I have a 5740C, the pto switch will not turn off. The tractor will not start with the pto turned on. Anyone have suggestions?
/ Electric switch pto #2
Replace the switch. Pull the wires off the switch so you can use the machine.
Thanks, Is this a common thing with the pto switch?
/ Electric switch pto #4
Try a TBN "search" with your Montana Mdl# and see if anyone else has reported simular issues.
Boone
/ Electric switch pto #5
My 2007 5740 has a dfferent problem with the PTO switch. It will not activate the Manual mode. It still functions in OFF and continuous though. I suppose I ought to get a switch on hand before I get stranded.
As a second thing to check before replacing the switch, look for wiring damage from rodents or other damage first.
/ Electric switch pto #6
I know that if the pto switch is on, the starter will not turn the motor over to start. That is a safety, that is built into the unit. The pto switch is wired into the clutch pedal switch, which in turn goes to the starter solenoid . As far as the pto not turning off, That is a new one to me. Usually, they won't engage, which is usually a wiring issue. I suppose, a switch could go bad, but haven't seen that to often. Maybe, you'll get lucky with a new switch, but I have my doubts. I'll have to check the wiring diagram, as I have not had many issues, of this kind, locally.
1996 Vermeer V-3550 Ride-On Trencher (A61572)
1996 Vermeer...
Katolight SED60FJJ4 75kVA Towable Diesel Generator (A61572)
Katolight...
3PT CARRY ALL (A63291)
MILITARY STYLE S/A CARGO TRAILER (A63291)
MILITARY STYLE S/A...
2025 SAWYER 85BP20 20FT T/A ENCLOSED BUMPER PULL TRAILER (A59912)
2025 SAWYER 85BP20...
Massey Fergusson 4710 (A60462)
Massey Fergusson...
