lennyzx11
- Joined
- Dec 20, 2015
- Messages
- 1,257
- Location
- Bennington Vermont
- Tractor
- Kubota L3301 HST/LA525 & 1964 Ford 2000 gas
I made log splitter with electric motor drive.
As I'm from other side of the pond (as will my friend @Sawyer Rob tell), I'm not so familiar with your measuring system, so I'll explain it in SI (metric units) and try to convert in US units.
My splitter is driven by 3ph electric motor (3x400V, 50Hz) w. nominal power 5,5kW continuous, about 1400rpm.
Pump is 19 ccm/rev, over pressure valve set @200bar. So, about 27 lit/min flow.
At full pressure motor is loaded with 9,5kW (intermitent @200bar peak Pressure).
Hydraulic cylinder is 80/56mm dia (piston/rod), and at 200 bar splitting force is limited to 10ton.
Let put units in US:
Hyd. cylinder is 3,15/2,2in dia.
Motor 7,5HP (continuous).
Pump 1,159 cuin/rev, at 1420rpm give 7,1gpm
Pressure (max): 2900psi
With mentioned pump at 2900psi motor is loaded with ~13hp (motor is shortly overloaded 73% more then nominal power).
Now you can rough calcualate ratio:
your motor is 2hp, and as is 1ph, I doubt that you can overload it more then 50%, say 3HP max.
So 3/13*7,1...You can pull out 1,6gpm@2900psi max.
For that 1,6gpm@3450rpm, you have to buy pump with 0,11cuin/rev.
Honestly, this splitter will be very slooow (if you need force) or weak (if you want speed).
For example, if you find cylinder like I have (3,15in dia), it will move 0,8in/sec.
A 2 stage pump makes a lot of difference in the power required and work well on wood splitters. You can get 11 gpm at 600 psi or so and 2500 psi at a much lower flow.
This is what I was using as a premise that it may work.
Now to see what the theoretical tonnage force would be at the 600 psi and 3.6 gpm of the first stage.
EDIT
It appears to be 7536 lbs or 3.75 tons of force with a 4 inch cylinder.
Somewhat weaker than the advertised 5 tons of force of my DR 5 ton splitter.
Thank you ZJ_HR.
I have read and seen videos of many ideas that have come from your country. It is great to see the different ways that different societies handle a common task to all.
You have a very interesting splitter, but I can't quite figure it out, unless - - what length are your splits? It looks very short between the push plate and the wedge. It looks like lengths are adjustable and that when in use, the overall length of the splitter is about twice as long. Do you have a picture of it in use?
