MossRoad
Super Moderator
- Joined
 - Aug 31, 2001
- Messages
 - 65,435
- Location
 - South Bend, Indiana (near)
- Tractor
 - Power Trac PT425 2001 Model Year
no, By that logic, a 2 cylinder 2 stroke gas engine rated at 20 HP should need a 10HP electric motor to replace it!..
the DC electric brushed motor makes power during the full rotation, each time the commutator aligns with a brush, torque is produced so you get more torque than a gas engine, which relies on a flywheel to keep the engine turning.. it's only single phase AC induction motors that only make torque each 180 degrees, and three phase AC induction motors make torque each 120 degrees. I did not yet correct my original post on this.In all reality, a 20hp engine and a 20hp electric motor both make 20hp. Horsepower is horsepower is horsepower.![]()
Yes, current as in time. :laughing:
One thing I was thinking about. Since the PT425 is all hydraulic, and the gas motor only turns one-way, all you'd need is an electric drive motor and an on-off switch. No reversing circuit would be needed and no speed control would be needed. You could put in speed control for the electric motor, but would it really help anything? You need full flow to create enough pressure to do the steering/FEL functions well. The AUX PTO wouldn't need full pressure, but since it's fed from the same valve bank as the FEL, which is fed from the power beyond on the steering valve, it's gonna get the same pressure anyway.
I suppose you could put in some sort of sensors to only apply the motor when the forward are reverse pedals are pushed, but I think response would be awful. And then you'd have to figure out circuitry to do the same for the FEL and steering. That's why I'd think you always want the electric motor on at speed all the time.
Just some thoughts.
