Effect of un-level trailer
   / Effect of un-level trailer
Sometimes things are rated one way and not another simply because they were not tested both ways.
That's a good point. I'm not trying to convince anybody either way. Just wanted to make sure a fully informed decision was being made. I'm sure it will be fine.
   / Effect of un-level trailer #22
Bruce
I doubt they would take the effort and publish information without testing. My guess is if it has a gusset (diagonal brace), these are strong in tension but not compression. Like a guy wire on a power pole.
   / Effect of un-level trailer #23
Is this a big deal? Do I need to pony up the $100 or so for a shank with sufficient drop?
Just to give you another point of view, an adjustable ball mount with enough rise / drop height to do whatever you need is a good investment. I carry the Curt D900 with me whenever I tow my bigger trailer just in case I need to make an adjustment once the trailer is loaded up Curt Multi-Ball Adjustable Ball Mount for 2" Trailer Hitches Curt Ball Mounts D900
These are really nice if you are picking something up and you just don't know what you are going to need. Sometimes I rent towable generators and when I do that I bring that D900 and a straight mount (no drop/rise) because I don't know what I will need until I get to the rental yard to pick it up, they could give me one generator one week and a different one the next. Picking the things up myself instead of paying their delivery fee more than pays for the $135 mount in one rental, they charge a lot to deliver things!
   / Effect of un-level trailer #24
^^^^ I agree with this statement but there should be no guessing when it comes to towing. Use components that are designed for the intended application. Likewise, set your trailer up so it's level when properly loaded. A generally accepted guideline is that 10-15% of your level bumper pull trailer's weight goes on the tongue. Load the trailer appropriately then tweak the rest of your system (drop shank, airbags for the truck, etc.)
Towing is dangerous enough even when things are properly set up. One certainly would not want to create unnecessary risk. I had to buy a longer drop shank for my old bumper pull horsetrailer when I changed from a chevy half ton to a dodge 3/4 ton five years ago. I still used the same WD setup but to get the trailer level I had to get a longer shank. It cost me about $120 at the time but it was money well spent.
Thanks everybody. I've ordered the proper shank and will be towing level.
2020 CATERPILLAR 306 CR EXCAVATOR (A60429)
2020 CATERPILLAR...
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
1981 LINK BELT HSP 8028 (A58214)
1981 LINK BELT HSP...
2018 PJ TRAILER 32FT GOOSENECK TRAILER (A55745)
2018 PJ TRAILER...
1995 Stoughton Enclosed Dry Van Trailer, VIN # 1DW1A5323SS900663 (A57453)
1995 Stoughton...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
