Easier way to move trailers with loader
   / Easier way to move trailers with loader #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
After reading of people unable to see the trailer ball while moving trailers, I thought to post these pictures. FYI. I don't have trouble moving trailers and by tilting the bucket can usually see the ball. Moving is quick and easy.
I didn't make this thing but did heavily reinforce it after it bent under heavy trailers. I got it in Kentucky with a trade and these are not my welds. It just an extra long bucket clamp arrangement welded to a long style receiver tube. By using the long style hitch and ball, the extra length makes it easier to see except when the trailer is real low to the ground. Then I have to crook my neck or lean forward.
The extra-long makes it work and I can usually hook up in seconds. Surely others have made better so if you have a pic, post it.
   / Easier way to move trailers with loader #2
I made one years ago, very similar. Let me find a pic. Was green when used on olj JD870, grey on my kioti
   / Easier way to move trailers with loader #3
I have a QA receiver hitch for the SS. It is the absolute bomb. I can wiggle a trailer into a shoe with it. :D
   / Easier way to move trailers with loader #4
Hole toward the end of one of my pallet forks works great for adding a ball when needed. Only takes a second and only need to hand tighten when doing a quick move.
   / Easier way to move trailers with loader #5
Inverted drop-hitch insert from a yard sale, receiver from HF. Turnbuckle for stability on lightweight bucket.
I can see the ball from the seat.
Bruce
   / Easier way to move trailers with loader #9
   / Easier way to move trailers with loader #10
I use a clamp on ball for moving my equipment trailer into and out of the lean-to on my pole barn. It's very tight, so the tractor fel gives me much more control and visibility.
2025 Electric Cart (A55853)
2025 Electric Cart...
2016 Volkswagen Jetta Sedan (A55853)
2016 Volkswagen...
2008 Bobcat T190 Compact Track Loader (A57024)
2008 Bobcat T190...
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A55852)
2016 Ford F-550...
Ford BL223C Utility Tractor (A55851)
Ford BL223C...
UNUSED JCT 40' CONTAINER (A51244)
UNUSED JCT 40'...
