E MAX HYD LEAKS
/ E MAX HYD LEAKS #1
Jabonee
Platinum Member
Pennsylvania
Mahindra
OK we all know Mahindras leak. Anyone out there with an E MAX noticing a slight leak around where the HST mounts to the front of the trans? Just below and to the left of that pain in the:censored:HST filter? Maybe a few drips on top of you MMM. The unit I have in here now is the 4th or 5th I've noticed it on. Not a bad leak. Just enough to wet the lower case and make the grass stick.:confused:
/ E MAX HYD LEAKS #2
Not all Mahindras leak. I'd guess most don't.
/ E MAX HYD LEAKS
Just spoke to my DSR about this leaking issue. He has been seeing a few E Maxs leaking in that area. Seems there is an issue with the O- ring between the HST and transmission housing. If you have a E MAX you may want to check it before your warranty runs out.:thumbsup:
IRONCRAFT 2515 BATWING ROTARY MOWER (A64280)
IRONCRAFT 2515...
Lucknow 360 Feed Wagon (A63688)
Lucknow 360 Feed...
2026 NORSTAR IRONBULL T/A 25FT GOOSENECK TRAILER (A59912)
2026 NORSTAR...
UNUSED SDLANCH RIDE ON SKID STEER (A64280)
UNUSED SDLANCH...
2019 JCB 2TS-7T High Flow Compact Track Loader Skid Steer (A61572)
2019 JCB 2TS-7T...
2022 JOHN DEERE 26G EXCAVATOR (A64279)
2022 JOHN DEERE...
