E MAX HYD LEAKS
/ E MAX HYD LEAKS #1
Jabonee
Pennsylvania
Mahindra
OK we all know Mahindras leak. Anyone out there with an E MAX noticing a slight leak around where the HST mounts to the front of the trans? Just below and to the left of that pain in the:censored:HST filter? Maybe a few drips on top of you MMM. The unit I have in here now is the 4th or 5th I've noticed it on. Not a bad leak. Just enough to wet the lower case and make the grass stick.:confused:
/ E MAX HYD LEAKS #2
Not all Mahindras leak. I'd guess most don't.
/ E MAX HYD LEAKS
Just spoke to my DSR about this leaking issue. He has been seeing a few E Maxs leaking in that area. Seems there is an issue with the O- ring between the HST and transmission housing. If you have a E MAX you may want to check it before your warranty runs out.:thumbsup:
3 Point Backup Attachment (A61166)
3 Point Backup...
Vision 250/50R15 77D Golf Cart Tires (A61166)
Vision 250/50R15...
New/Unused 7ft Fork Extension (A61166)
New/Unused 7ft...
2018 Forest River Cherokee Trailer, VIN # 4X4FCKB26JX130699 (A61166)
2018 Forest River...
UNUSED WOLVERINE JMR-22-8.5G SUSPENDED RIPPER (A62131)
UNUSED WOLVERINE...
Schulte SBW800 Rock Windrower (A63118)
Schulte SBW800...
