E MAX HYD LEAKS
/ E MAX HYD LEAKS #1
Jabonee
Platinum Member
Pennsylvania
Mahindra
OK we all know Mahindras leak. Anyone out there with an E MAX noticing a slight leak around where the HST mounts to the front of the trans? Just below and to the left of that pain in the:censored:HST filter? Maybe a few drips on top of you MMM. The unit I have in here now is the 4th or 5th I've noticed it on. Not a bad leak. Just enough to wet the lower case and make the grass stick.:confused:
/ E MAX HYD LEAKS #2
Not all Mahindras leak. I'd guess most don't.
/ E MAX HYD LEAKS
Just spoke to my DSR about this leaking issue. He has been seeing a few E Maxs leaking in that area. Seems there is an issue with the O- ring between the HST and transmission housing. If you have a E MAX you may want to check it before your warranty runs out.:thumbsup:
2021 PETERBILT 388 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2021 PETERBILT 388...
2020 Ford F-150 4x4 Ext. Cab Pickup Truck (A61573)
2020 Ford F-150...
2021 CATERPILLAR 745 OFF ROAD DUMP TRUCK (A62129)
2021 CATERPILLAR...
2016 Dodge Charger Sedan (A61574)
2016 Dodge Charger...
John Deere 4955 (A64119)
John Deere 4955...
Challenger 35/45/55 Parts and Operation Manuals (A63117)
Challenger...
