Dump / Utility Trailer Combo
/ Dump / Utility Trailer Combo #1
Daves3032E
Middlesex, NY
John Deere 3032E
Sorry if this has been discussed before, but from a few minutes of searching I didn't come up with much. I currently have an 18 ft utility trailer to haul my 3032e and wood splitter to places to gather firewood. I have been gathering about 25 cord per year (sell most of it for not a lot of profit). Loading wood in log form is easy, but then I have a heck of a time getting it unloaded at home (tractor gets left behind). Or I can buck it up, but then it takes a while to load and unload. I do most of my processing back home when I have time. It would be great if I could use a dump trailer to haul everything, but they get way to heavy for the size that I would need. Not sure if a 14 ft trailer would even be big enough.
I came across these guys with a combo dump / utility trailer: Side Dump
On CL I saw one that was very similar but the dump was over the axles and and a utility deck out front - I think this would be ideal.
Has anyone here used these types of trailers? Thoughts?
Attached is my current set up.
/ Dump / Utility Trailer Combo #2
There is a place around Toledo Ohio called Ron's Trailers. He makes a flatbed that will go high enough to dump stones/whatever. He will also build whatever you want.
Ron's Trailers, Inc. 419-691-RONS(7667)
Thanks for the link. Something like that is exactly was I was looking for. I sent an email and now waiting for a response.
/ Dump / Utility Trailer Combo #4
A lot of low profile dump trailers have ramps for loading equipment. Althougth you'll need more truck than that Dakota, empty the trailer will be 3000lbs.
Wish we could get a RAM 2500 Crew Cab 4x4, but we just can't swing it. I keep an eye out, but never seem to find any that we can afford.
Here is another option if you got the money. You will need a bigger truck for this one also.
Big Dog Trailers
That's a nice looking trailer. The more I look into this the more it looks like I'm going to have to figure something out with my current trailer... Not sure what exactly, but something.
/ Dump / Utility Trailer Combo #8
I have a 20ft Lamar brand dump/utility combo.
Like all things it is a compromise as it does not do either job as well. It's a little higher than a standard utility to clear the lift ram and does not reach the same angle as a dedicated dump trailer so it does not dump as well if you have a 'sticky' cargo.
Mine has a normal rail and removable sides and rear gate about a foot tall.
It's a little short for the bush hog though.
I looked on their website, but did find that type of trailer listed. The closest I was able to find was a tilt deck. Maybe they don't make them anymore? Or I just didn't see it - that's a good possibility!
I did get a response back from Ron's Trailers. They can do something very much like a concept that I put together for around $8,500. I would like to think that this would work really well for me:
/ Dump / Utility Trailer Combo #10
Brilliant. The Ron's trailer site still has plenty of pics (scroll down) of the hybrid equipment/dump trailer. As long as it has some stake pockets for adding side rails, I love it. The angle shown in bigkrank's first photo above is plenty for dumping some rocks/dirt, etc.
/ Dump / Utility Trailer Combo #11
I wish I'd known about side dumps like the trailer noted in the link of the first post. Probably not as much capacity for material as a dedicated dump trailer, but very nice to haul some material and a skid steer to a location.
I'm not really in that type of business, but I have had a couple of instances where I had to load the Bobcat, take it to a site and unload it and then proceed to wherever I was picking up material.
/ Dump / Utility Trailer Combo #12
No it's not on their website. But they do make them, it was under $6k.
That tilt deck looks good though.
2012 Ford F-450 Ambulance (A64556)
2012 Ford F-450...
2018 PETERBILT 520 6X4 T/A GARBAGE TRUCK (A66091)
2018 PETERBILT 520...
2016 Ford Escape SUV (A64557)
2016 Ford Escape...
2021 DITCH WITCH HX30G VACUUM TRAILER (A63276)
2021 DITCH WITCH...
2015 Ford Explorer SUV (A64557)
2015 Ford Explorer...
2013 VOLVO VNL630 6X4 T/A SLEEPER TRUCK TRACTOR (A67147)
2013 VOLVO VNL630...
