Dump / Utility Trailer Combo
/ Dump / Utility Trailer Combo #1
Daves3032E
Middlesex, NY
John Deere 3032E
Sorry if this has been discussed before, but from a few minutes of searching I didn't come up with much. I currently have an 18 ft utility trailer to haul my 3032e and wood splitter to places to gather firewood. I have been gathering about 25 cord per year (sell most of it for not a lot of profit). Loading wood in log form is easy, but then I have a heck of a time getting it unloaded at home (tractor gets left behind). Or I can buck it up, but then it takes a while to load and unload. I do most of my processing back home when I have time. It would be great if I could use a dump trailer to haul everything, but they get way to heavy for the size that I would need. Not sure if a 14 ft trailer would even be big enough.
I came across these guys with a combo dump / utility trailer: Side Dump
On CL I saw one that was very similar but the dump was over the axles and and a utility deck out front - I think this would be ideal.
Has anyone here used these types of trailers? Thoughts?
Attached is my current set up.
/ Dump / Utility Trailer Combo #2
There is a place around Toledo Ohio called Ron's Trailers. He makes a flatbed that will go high enough to dump stones/whatever. He will also build whatever you want.
Ron's Trailers, Inc. 419-691-RONS(7667)
Thanks for the link. Something like that is exactly was I was looking for. I sent an email and now waiting for a response.
/ Dump / Utility Trailer Combo #4
A lot of low profile dump trailers have ramps for loading equipment. Althougth you'll need more truck than that Dakota, empty the trailer will be 3000lbs.
Wish we could get a RAM 2500 Crew Cab 4x4, but we just can't swing it. I keep an eye out, but never seem to find any that we can afford.
Here is another option if you got the money. You will need a bigger truck for this one also.
Big Dog Trailers
That's a nice looking trailer. The more I look into this the more it looks like I'm going to have to figure something out with my current trailer... Not sure what exactly, but something.
/ Dump / Utility Trailer Combo #8
I have a 20ft Lamar brand dump/utility combo.
Like all things it is a compromise as it does not do either job as well. It's a little higher than a standard utility to clear the lift ram and does not reach the same angle as a dedicated dump trailer so it does not dump as well if you have a 'sticky' cargo.
Mine has a normal rail and removable sides and rear gate about a foot tall.
It's a little short for the bush hog though.
I looked on their website, but did find that type of trailer listed. The closest I was able to find was a tilt deck. Maybe they don't make them anymore? Or I just didn't see it - that's a good possibility!
I did get a response back from Ron's Trailers. They can do something very much like a concept that I put together for around $8,500. I would like to think that this would work really well for me:
/ Dump / Utility Trailer Combo #10
Brilliant. The Ron's trailer site still has plenty of pics (scroll down) of the hybrid equipment/dump trailer. As long as it has some stake pockets for adding side rails, I love it. The angle shown in bigkrank's first photo above is plenty for dumping some rocks/dirt, etc.
/ Dump / Utility Trailer Combo #11
I wish I'd known about side dumps like the trailer noted in the link of the first post. Probably not as much capacity for material as a dedicated dump trailer, but very nice to haul some material and a skid steer to a location.
I'm not really in that type of business, but I have had a couple of instances where I had to load the Bobcat, take it to a site and unload it and then proceed to wherever I was picking up material.
/ Dump / Utility Trailer Combo #12
No it's not on their website. But they do make them, it was under $6k.
That tilt deck looks good though.
2022 EZ-GO ELITE...
2005 Lexus ES 330 Sedan (A64194)
2005 Lexus ES 330...
2015 Ford Escape 4WD SUV (A64557)
2015 Ford Escape...
2006 Heil DOT 406 9,500 Gallon Comp T/A Fuel Tanker Trailer (A64194)
2006 Heil DOT 406...
1997 International 3800 School Bus (A64194)
1997 International...
2019 Freightliner 122SD (A62679)
2019 Freightliner...
