Dump truck repair
/ Dump truck repair #1
ticolawnllc
Bob Cat CT120
A while back one of my workers damaged my rack body dump truck. Some of the racks were messed up good. I was hoping some one could help me find an online dealer that I could use to find new racks or parts to make my own.
/ Dump truck repair #2
You will probably need to know the manufacturer of the dump body. Should be a tag somewhere on the body. There are so many out there and the racks may be different for each company. Or take some exact measurements of the racks you need to replace and compare to other companies racks.
/ Dump truck repair
It's a reading rack dump body
/ Dump truck repair #5
for sure.. post pics...
/ Dump truck repair
The truck had front end damage too. It's at the shop getting fixed up. I'll post pics when I get it back to the house
/ Dump truck repair
Let's see if this helps
/ Dump truck repair #8
pretty standard stake body but here is a link: 406 Not Acceptable You will have to find the nearest dealer and all that, but it looks like they are available.
edit: not sure what the 406 not acceptable means, but google it and you'll find it.
/ Dump truck repair #9
I see some simple sheet metal damage ont he left upper rear tha tmight be some press and bend type repair.. same for the upright, or just toss in some rec-tube stock and tack in... looks like an afternoon after work and adult beverage sort of job?
/ Dump truck repair #10
I'm in. :)
Terry
/ Dump truck repair
The horizontal parts have some rust damage. Not a lot but I don't think they will bend back. Seeing that I'm going to take time to do this why not rebuild the back rack.
I don't want to buy a sheet metal break mostly
2250' of 5" Tile (A66408)
2250' of 5" Tile...
New/Unused Landhonor Mini Skidsteer (A65583)
New/Unused...
2018 Cat D6T LGP VPAT Dozer (A62679)
2018 Cat D6T LGP...
Ari-Hetra HDML-8 15,000lb Four Post Auto Lift (A64553)
Ari-Hetra HDML-8...
2021 Weber CF 2-IIHD Plate Compactor (A61572)
2021 Weber CF...
Engine knock
Engine knock
