Dump trailer vs. utility trailer
/ Dump trailer vs. utility trailer #21
I am very familiar with CAM Superline trailers (I live not far from the factory and there are tons of them on the road around here; Bri-Mar is also close to us). You are correct about the sides flipping down but most of those are for side-dump trailers. In that case you are still dumping the material onto the ground. If you need to shovel it off and flip the sides down the deck of the dump trailer is too high to be comfortable (the landscape trailer has a lower deck).
Believe me, if money and towing capacity didn't matter I would argue for the dump trailer too. Based on the info the OP posted I was just trying to point out the benefits of a landscape trailer for his situation (I say "landscape" but also include car trailers in that group).
I just used the CAM picture because it was the first one I found...just an example Lots of manufacturers offer folding sides for conventional rear dump trailers as an option. I know it was an option when I bought my Load Trail, but I can't see ever needing it for what I do.
The deck height shouldn't be too high to shovel/rack out of it...it's going to be higher than a landscape trailer, but still not super high. The deck on mine is 32", but they also offer the low-pro version that has a 25" deck height.
This sort of stuff is why I said there's no perfect trailer in my first reply....they all require a compromise. I'd actually love to have a much smaller utility trailer for when I'm picking up things like tractor implements because it's hard to get them in my cargo trailer (I have done it) and I don't need to pull 4,500lbs of dump trailer for such a small task. :eek:
/ Dump trailer vs. utility trailer #22
I agree with that. Sometimes my son mows for his great-grandfather who lives about 1.5 miles from us. It can be a pain to take our lawn tractor out to his place since I need to load it onto my 16' trailer and I need to be the one to haul it (my son just started driving and I don't let him pull that trailer yet). During those times I wish I had a small trailer that he could hook behind his truck and go without me!
/ Dump trailer vs. utility trailer #23
1.5 miles? I would just drive the mower. It's quicker than hitching up, loading, strapping down, I strapping, and in loading....
Chris
/ Dump trailer vs. utility trailer #24
Chris
Heck, I'd just let the son drive the mower and be done with it. Why get involved?
/ Dump trailer vs. utility trailer #25
That's what I'm saying. I learned finally, I'm 43 and pretty **** dumb, it's quicker to drive my tractor if it's under 5 miles.
I started off as a Super Trucker with a 30' 25K GN and a diesel dually. Now my 18' BP and a F150 does everything I need and if not I hire it done.
Chris
/ Dump trailer vs. utility trailer #26
Chris
Not an option on the roads he would have to take. Just too many blind corners and hills where people drive too fast.
Actually I'm thinking of just buying a cheap lawn tractor and leaving it at my wife's grandfather's house. Then my son can just drive out there and do the lawn whenever it needs it. But the old man is set in his ways and doesn't want us to do that!
During my research, came across this 5x10 single axle:
Hydraulic Dump Trailer 5x10 with Brakes 2 Ft. Sides Roofing Dirt Mulch Rock - SLE Equipment
It's unique in that everything else in this size is tandem with twin 3500lb axles. This one is a single 5200lb axle. The specs are actually a good match for my requirements, but I have a couple of concerns. The hydraulics and battery are under the dump bed, instead of the more common box on the A frame. Seems like it would be more vulnerable to damage, road spray, etc. Also, even though the axle is rated at 5200lbs, I find myself wondering about the tires. Seems like a lot of weight for just two. Do they make 15" tires with that high of a weight rating? Specs on the page are kinda sparse. I'll call them for more info on that.
And has anybody here bought from SLE? I don't know anything about them.
/ Dump trailer vs. utility trailer #28
You can get 15" tires in LR E that handle 3K each.
Chris
/ Dump trailer vs. utility trailer #29
No way I would get a Single Axle trailer over 3500# though.
Chris
/ Dump trailer vs. utility trailer #30
What about a tilting equipment trailer? Equipment can be loaded and unloaded very easy and it aides removal of stuff like gravel and mulch.
If the right deal came along on a tilting trailer, and I could add sides to it, I'd consider it.
Ease of equipment loading and unloading is a lower priority for me. I need to be able to do it occasionally. I can cope with ramps for the handful of times a year I load equipment. Material handling (mulch and dirt) and safely moving household goods (in fair weather) are more critical tasks.
/ Dump trailer vs. utility trailer #32
i agree a dump trailer will be heavy just empty. And depending on how long in the future your truck purchase may be the payload you can load will not be that much before your at the top end of your tow capability. And you really don't want to tow at the top end much.
/ Dump trailer vs. utility trailer #33
He said the dump trailer he's considering (5x10 7K rating) was just under 2,000lbs empty. If anything we're probably talking 1,000lbs difference in payload between that dump trailer and some of the landscape trailers people are recommending....not exactly the end of the world.
/ Dump trailer vs. utility trailer #34
Build a 電ump box that sets inside your utility trailer. The box should have a removable back panel.
I知 going to build a 4x8 or 5x10 .. by one foot deep....to go inside my double axle utility trailer
Build a box..put casters underneath. Back up to your dump site , remove back panel, and push the box out the back.
I知 making mine that will attach to my trailer winch so I can actually lift my dump box
I have a 6 x 16 , double axle that will hold 5000 lbs ( I would need more than 1-1/2 tons at a time)
/ Dump trailer vs. utility trailer #35
Build a “dump box”that sets inside your utility trailer. The box should have a removable back panel.
I’m going to build a 4x8 or 5x10 .. by one foot deep....to go inside my double axle utility trailer
I’m making mine that will attach to my trailer winch so I can actually lift my “dump box”
/ Dump trailer vs. utility trailer #36
I had a 5’x8’ single axle, with approximately 2ton payload. Worked well, could pull it with just about anything. I picked it up from a rental place for $1300. Sold
It 5 years later for $1850, when I bought my 6x12 dual axle. It was a good trailer and worked hard.
Case 580 Super E Backhoe Loader (A66285)
Case 580 Super E...
2020 Komatsu PC210LC Hydraulic Excavator (A64553)
2020 Komatsu...
2023 JOHN DEERE 310P BACKHOE (A65053)
2023 JOHN DEERE...
Farm & Home 40-gallon UTV Sprayer (A66408)
Farm & Home...
HEAVY DUTY MILITARY TENT (A63276)
HEAVY DUTY...
2018 BOBCAT MT85 STAND-ON SKID STEER (A65053)
2018 BOBCAT MT85...
