Dump trailer update
/ Dump trailer update #11
Wouldn't want a counter weight as that would reduce your overall towing capacity but they DO make side dumps that alleviate SOME of the c of g problem /w3tcompact/icons/smile.gif
/ Dump trailer update #12
You can always pull forward. You can't dump higher than the bed is off the ground if that makes sense.
A dump truck makes bigger piles because the bed is higher off the ground.
/ Dump trailer update #13
Pulling forward will not change the position of the weight behind the rear axle. That just lets you spread as you dump.
/ Dump trailer update #14
Load shifting picking up the back end of a pickup is an almost impossibility unless the operator is being flat stupid. About the only load that will hang up as you tip is sticky mud, or a load that froze in the trailer. Either can be handled easily by installing a vibrator on the dump bed.
Anybody who continues to tip a hung load expecting gravity to discharge it is a complete fool and shouldn't be driving so much as a bicycle. If the load isn't dumping at 30 degrees of tilt, you stop tipping and find out why.
2025 AGT YC-32G Saw Mill (A53317)
2025 AGT YC-32G...
Electronic Towable Sign Board (A61166)
Electronic Towable...
2016 Case Magnum 310 (A60462)
2016 Case Magnum...
2013 Ford F-450 Mason Dump Truck (A59230)
2013 Ford F-450...
2012 Ford F-250 Pickup Truck (A59230)
2012 Ford F-250...
2013 Freightliner Forest River 390BH 39ft. Class A Motorhome (A59231)
2013 Freightliner...
