Dump trailer load equalizer hitch
/ Dump trailer load equalizer hitch #1
3Ts
Elite Member
East Texas
Case, Kubota, John Deere
I've been looking at dump trailers in the 14k GVW range and figure that I'll need a load equalizer type hitch for it. I have a Reese Equalizer for my RV trailer (11,000 # GVW) which works well and plan to use it for the dump trailer as well. However, the I-Beam type trailer does not accommodate the snap-up bracket. Welding in a plate to box the beam is an option, but the I-beam is 4" wide and the snap-up bracket only accommodates 2-3/4" wide frame. Even the square tube trailers are to wide. So, how do you put a snap-up bracket on your trailer tongue? Is there a particular brand that works?
/ Dump trailer load equalizer hitch #2
You but another set of brackets on Amazon and weld them to the frame.
/ Dump trailer load equalizer hitch #3
Okay.... Obviously you'll have to cut the bolt/clamp on party off to make it just the other face with the hooks. Then you weld it on.
/ Dump trailer load equalizer hitch #4
Check a different brand of dump trailer. I have a 16' 14K dump trailer. The tongue is 2"x5" C-Channel. Main frame is combination of 2"x8" box tube and 2 1/2"x8" C-Channel. Tongue takes my standard WD snap up brackets. Never seen a trailer with 4" wide I beam.
What brand of trailer do you have?
The PJ trailers I looked at this past weekend were I-beams 4" wide. They had a single telescoping cylinder at the tongue to lift the bed. Very nice setup. I want to find a MAXXD 14k trailer to check out, but all the dealers are 3 to 4 hours away. Have to combine that with another trip and be sure they're still in business after this COVID stuff.
/ Dump trailer load equalizer hitch #6
Here are a couple answers to that question over on etrailer.com
answer1
answer2
/ Dump trailer load equalizer hitch #7
My trailer is built by Cross Country Mfg. here in NY. Also a single cylinder. DSCN1122 (Medium).JPGDSCN1124 (Medium).JPGDSCN1129 (Medium).JPG
Pics do not show my WD hitch brackets as they were taken the day I brought it home.
Superior Trailer Product 15 Ton Yard Truck Ramp (A66736)
Superior Trailer...
Front Tank Bracket (A64126)
Front Tank Bracket...
2025 JMR Tree Boom Mini Skid Steer Attachment (A66734)
2025 JMR Tree Boom...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
2024 BOBCAT TL619 TELESCOPIC FORKLIFT (A65053)
2024 BOBCAT TL619...
SKIDDED STEEL ROLLER (A68842)
SKIDDED STEEL...
