Dump trailer load equalizer hitch
/ Dump trailer load equalizer hitch #1
3Ts
Elite Member
East Texas
Case, Kubota, John Deere
I've been looking at dump trailers in the 14k GVW range and figure that I'll need a load equalizer type hitch for it. I have a Reese Equalizer for my RV trailer (11,000 # GVW) which works well and plan to use it for the dump trailer as well. However, the I-Beam type trailer does not accommodate the snap-up bracket. Welding in a plate to box the beam is an option, but the I-beam is 4" wide and the snap-up bracket only accommodates 2-3/4" wide frame. Even the square tube trailers are to wide. So, how do you put a snap-up bracket on your trailer tongue? Is there a particular brand that works?
/ Dump trailer load equalizer hitch #2
You but another set of brackets on Amazon and weld them to the frame.
/ Dump trailer load equalizer hitch #3
Okay.... Obviously you'll have to cut the bolt/clamp on party off to make it just the other face with the hooks. Then you weld it on.
/ Dump trailer load equalizer hitch #4
Check a different brand of dump trailer. I have a 16' 14K dump trailer. The tongue is 2"x5" C-Channel. Main frame is combination of 2"x8" box tube and 2 1/2"x8" C-Channel. Tongue takes my standard WD snap up brackets. Never seen a trailer with 4" wide I beam.
What brand of trailer do you have?
The PJ trailers I looked at this past weekend were I-beams 4" wide. They had a single telescoping cylinder at the tongue to lift the bed. Very nice setup. I want to find a MAXXD 14k trailer to check out, but all the dealers are 3 to 4 hours away. Have to combine that with another trip and be sure they're still in business after this COVID stuff.
/ Dump trailer load equalizer hitch #6
Here are a couple answers to that question over on etrailer.com
answer1
answer2
/ Dump trailer load equalizer hitch #7
My trailer is built by Cross Country Mfg. here in NY. Also a single cylinder. DSCN1122 (Medium).JPGDSCN1124 (Medium).JPGDSCN1129 (Medium).JPG
Pics do not show my WD hitch brackets as they were taken the day I brought it home.
2013 VOLVO A40F OFF ROAD DUMP TRUCK (A65056)
2013 VOLVO A40F...
2025 Kubota RTV520 4x4 Gas Utility Cart (A66734)
2025 Kubota RTV520...
1 PALLET OF JACK & IMPACT GUNS (A66091)
1 PALLET OF JACK &...
2013 CHEVROLET CAPRICE CAR (A66091)
2013 CHEVROLET...
2023 Dodge Challenger Coupe (A66738)
2023 Dodge...
MINI ROCK GRAPPLE (A61572)
MINI ROCK GRAPPLE...
