Dump Trailer build
/ Dump Trailer build #44
Theres a couple good names right there but you might come up with a few of your own when you start building the scissor lift part and then tare it apart cause it dont work right, 3 times, oh wait thats me..........................
/ Dump Trailer build #46
Whats power to move scissor lift, hydraulic, winch or screw?
The scissor hoist is a dump bed kit from northern hydraulics. It was on an old pickup I had. It has 12v powered pump and is hydraulic.
I’m really starting to like this trailer as a skeleton. Delivered another load of logs to the Amish sawmill today. I’m thinking I’m going to leave hinges as pins that I can pull and make a log bunk for it that I can interchange.
/ Dump Trailer build #49
Two trailers in one, sounds good to me, although you can haul logs on a dump trailer to but you cant haul dirt on a log trailer.....
Well since losing my job this week I’ve had a little time to work on the trailer. The dump hoist is installed and works like a champ.
Hopefully later this week the Amish sawmill will have my boards cut for the flooring and the sides. Trying to find a 5x8 sheet of plastic or Teflon to put down on the floor to make it slick
/ Dump Trailer build #54
I was wondering what happen to this dump trailer build, it looks good, how'd the dump video come out, and whats the tailgate plan? To bad about your job, what happen and what was it? hopefully you can work something out and better...
I was a firefighter paramedic. But mistakes on my end combined with a bogus contract was a recipe for disaster.
I’m still coming up with an idea for the tailgate. Thinking I’m going to pin all 4 corners and make it like a tailgate on a pick up.
/ Dump Trailer build #58
I thought the tailgate in this video worked slick, I watched it 2 dozen times and for the life of me I cant figure out how it works, some how the linkage releases the dump as it goes up. If I make or buy a dump trailer that would high on my feature list, I hate getting off and on or in and out just to unhook tailgate, I like to drive down the woods road and as I go start dumping the load.
I haven’t been able to figure out the self unlock feature. I’m thinking I’ll stick to the idea of just pulling the pins.
/ Dump Trailer build #60
So what are you pulling this trailer with when finished?
2015 Ford F550 4x4 with 37' Bucket (A62613)
2015 Ford F550 4x4...
Bush Hog BH317 Rotary Cutter (A64047)
Bush Hog BH317...
(INOP) BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) BOMAG...
2017 HINO 268 4X2 S/A SERVICE TRUCK (A59910)
2017 HINO 268 4X2...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2019 Mack Granite Tri-Axle Dump w/ Lift Gate 006043 (A62613)
2019 Mack Granite...
