dumb question regarding remote hydraulic
/ dumb question regarding remote hydraulic #1
backwaterdogs
peoria, il
jd 4020
Dumb question here.
I had a remote hydraulic installed on my kubota. I just assumed was the same type I've always used the pioneer John deere. HOwever on the valve, there no collar to lock the connector in and then release to remove:
What heck am I missing here? any ideas? How can there not be a collar to release and lock the hydraulic coupling on the hose?
/ dumb question regarding remote hydraulic #2
Not sure but I think the casting "is the collar" or the collar is contained in the casting. I'm thinking that the tip can just be pushed into the coupler to engage.
thanks! I believe you are correct....but then do I have the right connector on my hose? is there a difference between this ball type i have and the poppet style? I thought they were suppose to be interchangeable
/ dumb question regarding remote hydraulic #4
The male tip looks more like the old John Deere style coupler prior to "John Deere/Pioneer".
yeah, it probably is...so do you think I have the wrong connector? any thoughts on the one I need? thanks again!
/ dumb question regarding remote hydraulic #6
just get one of the new style male pioneer connectors and put it on your hose you will be all set
/ dumb question regarding remote hydraulic #7
Correct. The sleeve is fastened to the block, so you push in to connect and pull out to disconnect.
The coupler on your tractor (in the grey block) looks like this left one and you need the right one on the end of your hose:
Pioneer Quick Coupling, 1/2 in. Double Acting Sleeve Set at Tractor Supply Co.
Aaron Z
/ dumb question regarding remote hydraulic #8
the on in your picture is the old style i think they are a 5060 pioneer, ih, jd, all had their own versions - the newer style are iso connectors and are now standard iso ag couplers, you can get ends to go on your hose or buy adapters to go from the port on the tractor to your hose, whatever you choose to do.
the one on your tractor is ISO
/ dumb question regarding remote hydraulic #9
Im not a fan of this style of connector because they always leak out a bunch of oil every time you unhook them. Keep a rag handy. You push them in to engage, push then pull to disengage.
Compact and convenient. Dust and dirt magnets. Keep the dust covers on to save yourself future grief. Label your hoses L and R.
/ dumb question regarding remote hydraulic #10
That's the old style Deere connector. Go to TSC and get you some Pioneer couplers and replace what you have.
2016 John Deere 470G Hydraulic Excavator (A64194)
2016 John Deere...
2010 Chevrolet Tahoe SUV (A64194)
2010 Chevrolet...
2005 Kubota L39 (A64126)
2005 Kubota L39...
Dual Tailwheel Rhino 284 7ft Cutter 2.5in cut capacity (A63689)
Dual Tailwheel...
JOHN DEERE LAWN MOWER (A65054)
JOHN DEERE LAWN...
New/Unused Landhonor Hydraulic Quick Attach Pallet Forks (A65583)
New/Unused...
