Drying Firewood
/ Drying Firewood
Thanks so the park police come and check you out. Can you sell firewood cut from trees in the park? Maybe that's what they are checking on if you can't
No so many firewood venders are not sell a rank or cord they have a gauge and you have to fill it up. Or if your selling wood from another state if I sell wood in Illinois it has to be grow in Illinois if I sell it in mo. It has to come from mo. They are cracking down on bulk firewood venders I sell a rack 4 x 4 for $20.00 people are buying them to see if they get what they pay for 2 of them hold a rank. Later
/ Drying Firewood #92
Millikilometrophobia is the fear that your johnson measured in inches will correspond to the same number in centimeters. This was what was found to be the leading cause of why the US didn't conform to the metric system.
Would scare the heck out me.:laughing:
But Imperial or Metric you are still left with the problem of convincing her that 7 is really 10.
Harry K
/ Drying Firewood #93
Just having wood is good.
/ Drying Firewood #95
That is a nice supply you have there, and nice stacking. I am down to about 10 cords left, and am already looking for more. Come spring I will restock for the season after next. I was given a heads up on some great locations already. That is one of the benifits of being a mechanic.
/ Drying Firewood #98
I know that -40 degrees C is pretty damned cold - so is -40 degrees F.:)
Good looking place you got there, Nick. Where's the sauna?
Touché :D
Thanks :) ... no Sauna, but we (I) aim to build a log-fired hot-tub sunk into the ground just at the edge of the pond. (under the eves of the large beech tree to the right) An old photo - taken before we re-built the roof, extended the house and extended the garage :) ... and to keep on topic: I cut back the willows around the pond 3 years ago. We're still burning the wood that came out of them. It doesn't have much energy in it, but it burns well and doesn't mess up the chimney :)
/ Drying Firewood #99
How long firewood will take to dry will depend on the temperature and relative humidity where you live. A poster from Texas mentioned that trees dead (or perhaps logs down) for 2--3 years would be dry, but that is not the case in the North Carolina mountains; I've seen logs down 5 or more years that were almost as wet as green when split.
Burning a mixture of green and dry wood will give a longer burn, but there are two disadvantages. First, a lot of the heat from the dry wood will be used in boiling the water in the green wood so that it can burn, reducing the stove temperature, and less of the dry wood's heat is available for heating your house. Second, this increases the chance of creosote buildup. But you can build up crosote even burning all dry wood if you keep the airflow reduced so much that the stove temperature is too low. Ideally, a fire with more airflow and less wood produces less crosote and a higher temperature than minimal airflow and lots of wood; of course, the stove full of wood will go without refilling longer.
The ariticle on covering wood stacks with clear polyethylene was interesting. If you leave a 1-2 inch gap at the bottom and a small opening at the top, drying is quicker because you get a chimney effect during the day, with cool drier air coming in at the bottom and hot moist air leaving at the top.
/ Drying Firewood #100
My comment on the plastic- covered wood drying with a chimney effect when there are top and bottom openings assumes it's in the sun!
2021 Ford Mustang Mach-E AWD SUV (A59231)
2021 Ford Mustang...
2019 Ford F-450 Altec AT200A 30ft Bucket Truck (A59230)
2019 Ford F-450...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2016 Ford F-150...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2005 Isuzu NQR 4 door box truck with folding gate (A61307)
2005 Isuzu NQR 4...
2025 14ft. Bi-Parting Driveway Gate (A59231)
2025 14ft...
