Drying Firewood
/ Drying Firewood #81
That is very nice. You have to love too split I love to take a big old knotty and work it to get all the split wood out of it I can. The state I live in you have cords 4 ft x 4 ft x 8 ft ranks are 4 ft x 8 ft x 16 inchs. I love to test ideas got one send it
So far all my splitting has been done with my trusty Hultafors splitting axe... At the moment I look at splitting machines and think "pffft - should do it by hand like REAL men" ... and once I've made my splitter I'll look at the axes and probably think "for people who don't know how to build splitters" :)
... Watching programs like "swamp loggers" and "extreme logging" the word "chord" comes up a lot: I always thought that it was a "big log" ... It's amazing what you learn on this forum :)
/ Drying Firewood #82
My woodshed and stove are made in feet and inches. My axes and splitting mauls are in pounds. I have no place to use metric firewood nor any way to make it. If I ever did make it, it would be for the export market.
/ Drying Firewood #83
:laughing:
My stove won't even burn metric forewood!!! :eek:
/ Drying Firewood #84
Do I sense a little metric fear? :D
My point was that we buy by physical measurement of the space taken by the wood, and the measurement is usually one of two ways: dumped or neatly stacked.
But don't worry: if your tools and toys are in imperial measurements, they'd still cut and burn metric wood: they'd just do it more accurately ;)
I use both sides of the tape measure, and still describe things in inches when it suits me, but for accuracy and to avoid crazy fractions, it's just easier (for me) :)
Each to their own eh? :thumbsup:
/ Drying Firewood #87
30 C degrees is pretty toasty if you ask me:laughing:
/ Drying Firewood #89
They are the Illinois people that check to see if what your selling is what your full rank or a cord. I live in the middle of a state owned park that covers southern Illinois
Thanks so the park police come and check you out. Can you sell firewood cut from trees in the park? Maybe that's what they are checking on if you can't
/ Drying Firewood #90
Millikilometrophobia is the fear that your johnson measured in inches will correspond to the same number in centimeters. This was what was found to be the leading cause of why the US didn't conform to the metric system.
Would scare the heck out me.:laughing:
/ Drying Firewood
No so many firewood venders are not sell a rank or cord they have a gauge and you have to fill it up. Or if your selling wood from another state if I sell wood in Illinois it has to be grow in Illinois if I sell it in mo. It has to come from mo. They are cracking down on bulk firewood venders I sell a rack 4 x 4 for $20.00 people are buying them to see if they get what they pay for 2 of them hold a rank. Later
/ Drying Firewood #92
But Imperial or Metric you are still left with the problem of convincing her that 7 is really 10.
Harry K
/ Drying Firewood #93
Just having wood is good.
/ Drying Firewood #95
That is a nice supply you have there, and nice stacking. I am down to about 10 cords left, and am already looking for more. Come spring I will restock for the season after next. I was given a heads up on some great locations already. That is one of the benifits of being a mechanic.
/ Drying Firewood #98
I know that -40 degrees C is pretty damned cold - so is -40 degrees F.:)
Good looking place you got there, Nick. Where's the sauna?
Touché :D
Thanks :) ... no Sauna, but we (I) aim to build a log-fired hot-tub sunk into the ground just at the edge of the pond. (under the eves of the large beech tree to the right) An old photo - taken before we re-built the roof, extended the house and extended the garage :) ... and to keep on topic: I cut back the willows around the pond 3 years ago. We're still burning the wood that came out of them. It doesn't have much energy in it, but it burns well and doesn't mess up the chimney :)
/ Drying Firewood #99
How long firewood will take to dry will depend on the temperature and relative humidity where you live. A poster from Texas mentioned that trees dead (or perhaps logs down) for 2--3 years would be dry, but that is not the case in the North Carolina mountains; I've seen logs down 5 or more years that were almost as wet as green when split.
Burning a mixture of green and dry wood will give a longer burn, but there are two disadvantages. First, a lot of the heat from the dry wood will be used in boiling the water in the green wood so that it can burn, reducing the stove temperature, and less of the dry wood's heat is available for heating your house. Second, this increases the chance of creosote buildup. But you can build up crosote even burning all dry wood if you keep the airflow reduced so much that the stove temperature is too low. Ideally, a fire with more airflow and less wood produces less crosote and a higher temperature than minimal airflow and lots of wood; of course, the stove full of wood will go without refilling longer.
The ariticle on covering wood stacks with clear polyethylene was interesting. If you leave a 1-2 inch gap at the bottom and a small opening at the top, drying is quicker because you get a chimney effect during the day, with cool drier air coming in at the bottom and hot moist air leaving at the top.
/ Drying Firewood #100
My comment on the plastic- covered wood drying with a chimney effect when there are top and bottom openings assumes it's in the sun!
UNUSED WOLVERINE QMP3-16-6T QUICK ATTACH PLATE (A62131)
UNUSED WOLVERINE...
2024 Kubota M7-174D (Deluxe) 4WD Tractor - 244 Hours (A63118)
2024 Kubota...
UNUSED SDLANCH BI-PARTING WROUGHT IRON GATE (A62131)
UNUSED SDLANCH...
2017 Ford Escape AWD SUV (A61569)
2017 Ford Escape...
UNUSED WOLVERINE GB-11-72W 72" HYD GRAPPLE BUCKET (A62131)
UNUSED WOLVERINE...
(2) 30 Yard Roll Off Dumpsters (A61165)
(2) 30 Yard Roll...
