Driveway edger
/ Driveway edger #1
Schultz
Dexter, MI
BX-2200
I started this post in the Power Trac section since I took the design from power trac. This edger is a single disc mounted on 1.5 in sq tube bolted to a mount that clips to the front of my Ingersol 448. I made it so the mower can stay on, it just clips along side the mower mount pins, and it uses the lift arm from the snow blower.
I started with a worn out disc from a farmer down the road. Made a bushing to weld the disc to. Used one of the few broken mower spindles I've saved as the shaft for the disc. Also used another mower spindle for the barbell weights. Weights were used so the lift could remain in the float position rather than fiddling with down pressure all the time.
As I reported in the PT site, it worked great after a few adjustments. I was surprised at the angle I ended up with on the disc. But now all I do is drop it next to the driveway and start driving. It took two trips up and down the driveway to cut all the sod and dirt. I imagine it will be less effort now that I have this and plan to use it more often. Now all I have to do is paint it.
/ Driveway edger
Drivers view
/ Driveway edger
Clip in mount
/ Driveway edger
It does a nice job of throwing the dirt and grass onto the driveway for easy clean up
/ Driveway edger
After picking up the dirt and grass it leaves a small furrow about 4-6" wide by 3" deep
/ Driveway edger #6
Nice set-up. Looks like it works well. Gerard
/ Driveway edger #8
<font color="purple"> Anyone ever try to do this using a rotary push mower or a string trimmer instead of the disk,so you could easly trim along ditches and under fences? </font>
/ Driveway edger
Not sure I understand your question, but I did use a string trimmer for several years as the driveway edger. But it didn't work all that well because I didn't do it that often and I have 550' of driveway. I would go through a spool of string and be covered in dirt and grass at the end of it. Which led me to find somthing more eligent like the disc.
Tim
/ Driveway edger #10
That sure is a lot easier than a string trimmer! I have seen very similar setups on tractors with FELs to edge curbs and sidewalks. Nice job.
2008 MACK CHU613 DUMP TRUCK (A63569)
2008 MACK CHU613...
Parker Gravity Wagon (A66285)
Parker Gravity...
UWS TBS-69 Truck Bed Tool Box (A64556)
UWS TBS-69 Truck...
New/Unused 76in Pallet Fork Extensions (A65583)
New/Unused 76in...
2017 Ford Explorer AWD SUV (A59231)
2017 Ford Explorer...
Snow Plow & Salt Spreader (A62613)
Snow Plow & Salt...
