Traction Drive train YANMAR FX24D
/ Drive train YANMAR FX24D #42
Winston, I have a good ring gear from a yanmar,will get u a pic,price is right if it will work, may need to machine the ID but its in great shape,how many teeth on the fx ?
/ Drive train YANMAR FX24D #44
Getting to the party late. Have a strong suspicion this is the same tractor/problem Winston wrote me about on another forum. For sure the ring gear is damaged and there is the question about what caused the shearing of the bolts and why/how 3 bolts were found laying loose in the case.
It probably doesn't matter here but maybe the info will be useful to some at some point. Yanmar offered an option for front drive only, to reduce the turning radius. Ernie had one and he let me drive it, sure did reduce the turning radius. The main purpose here is to make people aware of this option and if you end up with an issue like this, first make sure the tractor does or doesn't have this option and if it does, make sure it isn't engaged.
We sure lost one of the good guys when Ernie got out of the business and moved to the East coast.
/ Drive train YANMAR FX24D #47
not sure possible 950 john deere or a 336d, i have a few ring gears but the 40 tooth one described looked very close to the one you have in the photo
/ Drive train YANMAR FX24D #50
did you ever do any research or find anything about the front drive only models ? Thats an interesting tidbit, would like to see what models came that way....
/ Drive train YANMAR FX24D #51
Since I made this statement I need to make sure the option is clear to everyone. These are regular 4wh drive models where the rear drive can be disengaged to improve/tighten the steering radius. They are NOT 2wh drive models with only front wheel drive. The front drive only is intended for maneuvering the tractor in tight spaced and not to do any heavy work. Seem to recall the tractor was an F series.
The one I drove looked like every other Yanmar of the same model but had an additional lever to disengage the rear drive. Yanmar offered a lot of options you rarely see here as well as implements. Ernie had a Yanmar tiller with a shuttle mechanism. By moving a lever the tiller could be shifted either left or right on the go. Sure made it nice for getting up close to things like fences and such. Also recall a model Ernie had that had side by side seating.
/ Drive train YANMAR FX24D #52
I think that models that came with this feature were 3 digit F series. The first tractor that Ernie found this feature was an F215 but he also found it on the F235. I don't think it came on any 2 digit F series or before.
/ Drive train YANMAR FX24D #53
Just a short update. We are working with Mr. Sheaffer obtaining parts. Sheaffer's Town & Country Tractor Hopefully, this next week we will have them in hand. Here is a picture of the cut gaskets. I micrometered the material and bought it at O'Reilly's Auto in sheet form.
/ Drive train YANMAR FX24D #54
Mickey
Thanks for sharing,Yanmar did make alot of differnet tractore,equip and options and I for one really enjoy hearing some of these options..
Thanks from CT
/ Drive train YANMAR FX24D #55
Our fellow contributor and starter of this thread GWSMITH is having a knee replacement at 11:00am this morning. Any prayers for him at this time would be appreciated by GW and myself. I am starting to put his FX24D back together. I will take a few pictures along and hope we have a success story here.
/ Drive train YANMAR FX24D #56
Spoke with GWSMITH about 5pm. Surgery went well, he had just finished some broth and iced tea.
Make a little progress on the FX24D this afternoon. This picture is of the new ring gear installed.
/ Drive train YANMAR FX24D #57
This one with the axle housings installed.
/ Drive train YANMAR FX24D #58
This one for a shot of the differential lock.
/ Drive train YANMAR FX24D #59
Lastly, one showing the hydraulic unit installed. Notice the new over run clutch. We are going to try and prevent this from happening again. Probably be next week sometime before I get back. We are going to have a little R&R.
/ Drive train YANMAR FX24D #60
All I can say is, What a great GREAT JOB !! You're 1 HE!! of a person to be able to help this guy out !
1996 Aspen T/A Pump Trailer (A64194)
1996 Aspen T/A...
2013 Ford F-350 4x4 Crew Cab Pickup Truck (A64556)
2013 Ford F-350...
Stertil Koni 18000lbs Auto Lift Columns (A61572)
Stertil Koni...
Set of 4 Forerunner 12-16.5N.H.S. Skid Steer Wheels and Tires (A64553)
Set of 4...
2025 HT360W Mini Walk-Behind Track Loader Skid Steer (A64553)
2025 HT360W Mini...
2018 Nissan Titan 4x4 Crew Cab Pickup Truck (A64556)
2018 Nissan Titan...
