drill
/ drill #1
Anonymous Poster
Epic Contributor
Hi
i am interested to Know if anyone has ever seen or used one of these. maybe a business opportunity for me.
/ drill #3
I'll take 2 of those. I needed one just yesterday. I was putting this thingie together for the CFO. I told her if I just had one of those doo-hickies that will make the thingamagig fit in the whatchacall it a little better.......I'd have it made.
Seriously, I have no idea what it is..../w3tcompact/icons/grin.gif
Jerry
/ drill #4
I'm baffled, too. /w3tcompact/icons/hmm.gif
/ drill
Hi fella's
This was invented in Queensland Australia
It is a drill as the heading implied for drilling plate steel
USE (only for drill presses) It drills from 1/2 to in excess of 2" holes
(1) drill a 1/2 " hole with a normal twist bit
(2) adjust the bottom cutter on the shaft to suit the hole size you wish to drill then drill on the slowest spead possible.
(3) If you want to drill bigger than 1" do no1 then set the bottom cutter to 1" and drill that first, then adjust the second cutter to the size you want and then drill that.
I hope this makes sense.
/ drill #6
i am still confused/w3tcompact/icons/tongue.gif MABEY IT IS JUST CAUSE ITS LATE, and i am tired. /w3tcompact/icons/hmm.gif
/ drill
Hi fella's
I am having trouble explaining this tool but maybe this helps, (see attachment)
/ drill #10
Yes that's what it looks like to me too. Something like a fly cutter for boring. you adjust your cutter arm to set the diam of the hole you want. I would check out some machinists tool catalogs before I invested in it. The Chinese have made serious in roads to the low end tool market so you may not have the world by tail with them in the game.
/ drill #11
OK, I'm now officially un-baffled. Actually, it looks like a pretty neat toy. Without a drill press, I don't see one in my future, though. /w3tcompact/icons/smile.gif
/ drill
Mike
i have used it many times over the last 5 or 6 years. it is great, but you must use soluble oil with it.
Most times i have used it for drilling pin holes when i make attachments like front or back forks ect for the tractor, Its a cheap alternative to buying may different drill sizes.
2017 CATERPILLAR 980M WHEEL LOADER (A65056)
2017 CATERPILLAR...
2025 XKH39 39in Hydraulic 4-Way Clamshell Bucket Mini Skid Steer Attachment (A66734)
2025 XKH39 39in...
2015 CHEVROLET SILVERADO CREW CAB PICKUP TRUCK (A66091)
2015 CHEVROLET...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A  SLEEPER TRUCK TRACTOR (A69167)
2017 FREIGHTLINER...
2010 Chevrolet Silverado 1500 4x4 Ext. Cab Pickup Truck (A66736)
2010 Chevrolet...
2020 Ford F-150 4x4 Crew Cab Pickup Truck (A64556)
2020 Ford F-150...
