etpm
- Joined
- Jun 30, 2021
- Messages
- 2,389
- Location
- Whidbey Island, WA
- Tractor
- Yanmar YM2310, Honda H5013, Case 580 CK, Ford 9N
Some round column bench top mills have another problem that may not seem obvious until you use one. The quill will have only a limited amount of travel so if you are working on something that needs more travel than the quill has the head will need to be moved up or down. While doing this movement the head will also rotate a little bit one way or the other. When this happens you will lose your X and Y position.No-one said what the problem with round column mills was and I have no experience with them, but after reading about the Jacobs chuck damage due to side forces and a mention that round columns are a problem I put 1 and 2 together to figure out that with a round column the side forces are going to cause the cutter head to rotate around the column which means cutting a straight line will be very difficult. It just never crossed my mind until it was mentioned that round was a problem.
When the head is in the proper position it is of course tightened to hold that position. On a decent machine the head should be able to resist even overloaded machining conditions. But cheap machines often are not able to do this.
As a machinist with over 40 years experience machining I somehow became a machinist. I'm not sure when exactly it happened but it apparently it did. I mean I can make good parts most of the time. Since I am calling myself a machinist, and since I'm retired, it seems to me that I should be willing to answer machining questions. So, if anyone here has machining questions, and if they ask me, I'll endeavour to answer them. Like any skill, when first starting questions will need to be asked and answered. I encourage this. I have seen lots of excellent work done by hobbyists. It doesn't matter what somebody is interested in. It takes practice and learning. So if you want to try something new just try it out. Ask questions. Make some mistakes and learn from them. Try whatever you want. Except maybe surgery. Or controlled building demolition. Or Saturn 5 Rocket Boosters.
Eric
