Thumb Drill or seeder?
/ Drill or seeder? #11
I have slightly different take on the whole selection thing. How many times will you be running over the ground? With a drill you can get away with just 2 times. With broadcast you really need to go a 3rd time with a drag or cultipacker preferably. Just saying a drill might save 1 pass. Something to consider. Also which might you use in other cases in the future?
I agree if money doesn't play into the decision. A no till slit seeder or drill with cultipacker built in is a wonderful tool. The price even for a well used one reflects that.
/ Drill or seeder?
If I just wanted a way to plant corn what would you recommend? I have a disk and cultipacker but thought about buying one of the systems to do it all. Maybe just need a basic planter.
/ Drill or seeder? #13
If you don't care about rows I'd broadcast it at a low seed rate. Do you have a PTO or electric seeder to go on the back of your tractor?? It would work fine. Then light disk it in. Needs to be somewhere around 1.5" deep.
2014 Lincoln MKS Sedan (A59231)
2014 Lincoln MKS...
2013 Chevrolet Silverado 1500 Ext. Cab Pickup Truck (A59230)
2013 Chevrolet...
CATERPILLAR 924F WHEEL LOADER (A59823)
CATERPILLAR 924F...
Tandem Axle Rear Truck Frame (A59230)
Tandem Axle Rear...
NEW HOLLAND T4.75 POWERSTAR TRACTOR (A62130)
NEW HOLLAND T4.75...
2022 FORD E350 BOX TRUCK (A58018)
2022 FORD E350 BOX...
