Drill Bits
/ Drill Bits #41
It's better when you own your own machine shop as I do. I deal with Production Tool and Supply, KBC Tools www.kbctools.com and www.productiontool.com in Detroit, Michigan, MSC, and Enco which is the discount division of MSC. Enco doesn't have the large selection that the other 2 have and you will wait a few days for delivery, but their prices are quite low. Their website is: www.usenco.com. If we are in process on a job and I need some specialized tooling, I use Production Tool. I can pick it up the same day and they carry a lot of odd ball items. However, their prices are quite high. For the hobbyist or homeowner, Enco or Grizzly www.grizzly.com are the answer for inexpensive cutting tools or machinery. Just be aware that the quality is usually Chinese, not American unless stated.
Daryl
Forage Services, L.P.
/ Drill Bits #42
Here is a picture of my drill press . Not you run-of-the-mill chinese variety. American made, American quality, American price .
Daryl
/ Drill Bits #43
I've had a cheap set of drill bets for the last dozen years. I do everything wrong with them, drill too fast, I never lubricat, I drill through dirt, dust or whatever's in the way.
I use a Drill Doctor from Home Depot which cost around $80 and it just takes a seconds to sharpen a bit. I tried all the fancy angle tools for sharpening on a grinder whithout much luck except killing time.
When I need to drill through steel I just sharpen the bits I'm going to use and when I'm done I just put them away.
/ Drill Bits #44
I have been watching the ads for the drill Dr. are they as good as they claim,do they stay sharp? I never had much luck sharpening by hand-Thanks
/ Drill Bits #45
The Drill Doctors do a good job. They are not commercial quality and I am not sure how long they will last but they do a good job of sharpening and are easy to use.
/ Drill Bits #46
That thing looks like the robot on Lost In Space!!! Is Will around there? /forums/images/graemlins/grin.gif
/ Drill Bits #47
Not just american made, but industrial quality and not cheap by the looks of it. Does it also do milling ?
/ Drill Bits #48
Nice unit, Daryl.....ours have infrared data ports and can exchange setup info.
/ Drill Bits #49
Close up of earlier model. Note retractable table supports at outer sides of unit.
2018 JOHN DEERE 650K LGP CRAWLER DOZER (A64279)
2018 JOHN DEERE...
(1) 4' X 5' DIAMOND PLATE METAL SHEET (A64280)
(1) 4' X 5'...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
TEST YOUR BID BUTTON! (A64280)
TEST YOUR BID...
Toyota 2FGC20 4,000lb. Propane Forklift. (A61572)
Toyota 2FGC20...
2006 STERLING ACTERRA CAB & CHASSIS (A60736)
2006 STERLING...
